my 2722 m18 super sawzall sometimes shuts down while I'm using it, the trigger stops working. It's fixed by removing and reinserting the battery. Anyone else have this happen? It feels like a software glitch in the controller but who knows
Home Depot has Husky shelves in red. They are very close to Milwaukee red. Here is what I did to make the organizers easier to get to.
https://www.homedepot.com/p/Husky-4...f-Garage-Shelving-Unit-MR482478W5-R/308458506
Add casters and a handle and I would![]()
it happens under light use and with multiple different 8Ah and 12Ah batteries. it usually happens after I've ended a cut on my own terms, then I go for another cut ten seconds later and it doesn't go, and goes immediately after a battery remove/replace
Who here runs the Milwaukee 2830 rear handle circular saw. I want the left bald but am worried about the weight. I have the 2732 blade right saw but the visibility Is horrible and it’s heavy also. Just looking for any feed back from experience. I would probably run it with a 8ah instead of the 12ah to make it a little lighter.
What you you guys think. Is that saw a go or no go?
I want to replace my old corded two-speed Craftsman, but many reviews, even on the Milwaukee web site, are pretty bad. Should I hold off until they come out with an improved design? Any long-term users who have a good experience? This is for home garage use.
I have the older weed eater style not the new one with the interchangeable tools. I love it. Does a great job for me. It has 2 speeds, lower speed still does the job and extends the battery life. Mine came with a rapid charger and a 9.0 battery, but I have run it on a 5.0
Grab the over shoulder strap if you don't already have one that would work.
Ron
Placed my order for the left handed blade “worm drive” saw, 2830-20. Hoping it’s gonna be awesome. Ordered from Acme tool, everything went smooth. Only disappointment is the shipped it with FedEx. Would rather have UPS any day of the week.
Any one else having issues with their 700L usb rechargeable flashlight. My first quit charging, after little use over two months, my replacement battery was bad out of the box. #2 battery was bad out of the box. I realized there is a 2 yr warranty so I await #3 battery from Milwaukee.
It's quite a bit bigger than the Dremel so if you're using it for any sort of fine work maybe that makes it less ideal? But otherwise I think its great.
I don't frequent HD much...but was there around President's day looking for masks....
Have also been making daily trips on the way to or way from work. Managed to actually SCORE some masks....
Anyhow, the display boxes, etc, Milwaukees were brimming on Presidents day. Everyday when I pass by the display boxes, it does not look like Red is getting restocked at all......
I wonder how Harbor Freight is doing these days..
No, the negative reviews aren't about the size, they are about reliability. Apparently, they are prone to just quit working, lose speed control, etc.
I have the same light and have the same issue. Based on the reviews on the web (Amazon, HD, etc.) it appears that I’m not the only who has had this issue. These batteries seem to be ****. There are much better flashlights out there for that kinda $.
I have both the dedicated Milwaukee Weed Eater and the new Quik Lok Multi Tool System. If you need only a weed eater I would recommend the Weed Eater Only because it's lighter and has less vibration. The Quik Lok is awesome for the Hedge Trimmer and Pole Saw, but is quite heavy and will give you a workout.
Am I going to have issues drilling 5/16" about 2 in deep holes into solid concrete (basement) with the 2504 (M12 Fuel hammer drill)?
It should be fine doing that. Won't be fast, but it'll do it.
Ditto, I switched all my OPE to M18 last year and couldn't be happier. I've got a little over an acre, and one 9.0Ah gives me enough juice to weed eat and use the blower to clean everything off. Sooooooooo much better than dealing with the hassle of gas.I got my Milwaukee grass trimmer one year ago along with the tree limb trimmer (chainsaw) attachment. It is great! It replaced an old gas Stihl. I will not go back to gas & oil. I can trim around everything 4 times before recharging!
Can anyone share their experience cutting tile with a m12 cut off. I have a wet table saw but it doesn't leave a great edge. I am thinking I can at least score the surface to get a nice straight line when I put it on my table.
Thanks.
Levi
Anyone here have the M12 5 3/8 circ saw? Thinking about grabbing one to break down sheet goods and 2x material at the big box store. My other option is to go with the 18V Ridgid Octane version. I rarely use my corded circ saw these days now that I have a track saw, but alas it too is corded.
