Better Way to Not Get Smushed by HF Jackstands
BlackLS2
Since you are only issued the one set of legs...
$109 Each on Amazon Prime...shipped
ESCO 10455 Pin Style Jack Stand, Short Style, 22 Ton SINGLE Capacity (44 Ton Pair), Range 16 to 20 Inch.
driz
Northern NY
For those times when your dozer gets a [emoji848]flat leaving you broke down on the freeway.....
Shiftless
East Bay SFO
Ha ha
I looked up the weight of the biggest dozer I could quickly find. Caterpiller D10 weighing in at about 190,000 pounds. A one ton Silverado pickup 3500 has a top curb weight of 8,000 pounds.
So 4 of those jack stands would be only 10% over rated weight holding up the entire weight of this beast.
Use 6 of those jack stands and Bob’s your uncle.
Impressive jack stands!
Dumber than lumber
That jackstand would get you bragging rights most places.
Seems like one could make a nice grinder stand, etc. from one of those. I should look at smaller capacity model.
steaks&anvils
Colorado
Nice. Great price, easily worth the money for piece of mind.
I used to have a vintage rail road/house jack (lost it in the divorce). We would put that under the car and never worry about it falling. For lack of an easy source for house jacks, this one is great!
rlitman
Long Island
Damn. You'd better be wearing steel toed shoes around that thing in case you accidentally drop the pin.
But who wants ONE jackstand? If you want a PAIR of 22 ton stands, the Sunex 1522A pair is $157.43 on Amazon, so it's a better deal.
patchap
I've been using 6ton princess auto stands for 10+ years, had a 5ton dump truck on them for half a winter once.
Ratchet style stands are perfectly safe if they're not made eith bad tooling
Ralf11
ndnchf
Fredericksburg, Virginia
This may be overkill. But I made a serious jackstand out of a 10 ton screw jack. This has 1-3/4" diameter acme threads. Its a beast.
M635_Guy
NC
That's utter overkill for most of us. If I'm dropping a hundo per corner (and I'm tempted), I'm going with the Esco 10498K that gives you two tower options:
Jagmandave
Overland Park, Ks.
The cars I work on weigh about 1500lbs all in, so even the 3 ton HF stands are overkill for me. They also have very stiff chassis, I've seen it where I had it up on 4 stands and one wasn't touching! I fixed that......
Coach James
Sandhills of North Carolina
I was looking at 22 ton stands like the OP posted yesterday. Seems several brands are out there. As I get older, I don't mind spending a bit more money to make sure I stay alive. Lately, I've just been using 6 ton stands with the saddle all the way down.
Coach
Skin
Boston
Coach
Until something in your back goes out lifting it or you drop it on your foot. 35lb stands for a road vehicle is crazy.
Ralf11
The wooden posts holding up the truck are a safety feature. In the event of a fire caused by welding, they will burn thru and drop the truck, causing a big whoosh that will extinguish the fire.
BlackLS2
Yes, huge overkill. But...absolute confidence, especially under a full size SUV or pickup. The very definition of rock solid. With the design, and that much overbuild, things like weld inegrity, metal failure, ratchet mecanisms, are just not a concern. 99% of my tasks are one wheel. I also find it does not get in the way on tool arc like a tri leg can...just push the pin all the way in.
mike93lx
Richmond, VA
I really wanted both towers, but couldn't justify double the cost over just the flat, round one. That up charge is pretty crazy
toddmorr
Prescott, Arizona
we find out HF sells a dangerous tool, and suddenly everyone has to waste money on overkill jackstands. I don't get it. There are many sellers of perfectly good 3 and 4 ton stands that have excellent safety records and zero issues, and are more than adequate for any passenger car.
mike93lx
Richmond, VA
If you consider $50 to $100 is wasting money on high quality jackstands that I will have for 20+ years, we have different measures of what waste is
schurtjl
Oregon
I agree 100%. Working under a vehicle is one area where it’s not worth scrimping and saving a few bucks.
Tennessee Cattleman
East Tennessee
Those Esco 22 ton stands are impressive enough to get my attention. I really like this forum, but it does seem like a lot of the members assume everyone on here only works on cars and light trucks and therefore shouldn't want or need anything to work on heavier equipment and vehicles.
M635_Guy
NC
I don't think that's the assumption at all. Most people, even here, aren't working on vehicles requiring 22-ton stands though, and only idiots would have been using the HF stands on anything that big.
ndnchf
A design point I often find aggravating with many jack stands is the hole spacing for the pin. Some are 2" or more apart. Often it is too high or too low. The screw jack stand I showed about resolves this problem. It makes it very user friendly.
mike93lx
Richmond, VA
I don't think I have a countered a situation where I couldn't have either jacked up or lowered a vehicle by 1" to compensate. When has that been a problem for you?
ndnchf
I can adjust to make them work. But its nice to be able to jack it right where I want it. Then slip the jack stand into place and raise it right up to match.
Locker537
Massachusetts
I spent $200 on these jack stands recently and have been happy. Buy the low profile version if you work on lowered sports cars.
liliysdad
I am planning on replacing mine with the same thing from Harbor Freight...
Ign
Butte Peak ND
It's too bad the "original" thread about the extremely questionable welds on US Jack jackstands is so old the photos are gone....
Tennessee Cattleman
East Tennessee
These stands might be rated more than most people will ever need, even on heavier machines, but I do appreciate the person that went to the trouble to start this thread and add a picture of what looks to be a really fine jack stand.
I would feel much safer with a 5 ton load on this 22 ton stand, than a 5 ton load on a 3 ton HF stand, but then some people like to live life on the edge and that is their business.
:beer:
