Cast iron welding
peterj
NC
Can cast iron be welded - I'm pretty sure I know the answer but dose it take anything special ie: stainless steel wire or can I take a non-stressed part to any experienced welder.
Thanks for the help,
Pete
trbomax
starvation lake,mi.
Pete
You can stick weld it w/stainless rod,but the best way is to use rod for cast iron. Its a good idea to preheat the piece w/ a torch (if its small) and then use the torch to keep heat in the piece so that it cools slowly,otherwise it will crack right next to where you just welded. If its a a biger piece, heat it up in the oven, and cool it off in the oven. I did a 427 side oiler block a few years ago,took it to the shop where my son works,took 4 hrs to heat it up and 6 to cool it off,but it never broke while I had it.
ironheadtom
Kentucky
An experienced welder can make it into a thing of beauty. I've seen it done with stick with a rod that I believe has a high nickel content. Also I believe it takes a lot of pre-heat, post heat, and a slow cool down process. I never learned how to weld it myself , so I braze it when it's not a super important job. Even when brazing, I pre-heat, post heat, and then bury the part in kitty litter so it can cool as slowly as possible.(Sometimes taking many hours)
jon1996
My method is
PRE Heat to 350
Tig Weld with Stainless Steel
Post heat at 300 till cool down never had a problem,
Nickel rods work good to but I always used what I had on hand, you would not belive how many guys around here forget to drain their boats when winter comes
rsanter
visalia ca
if you pre and post heat and then slow cool you can mig weld it
what is it?
generally I preheat in a BBQ and then locally preheat the area to be welded with a torch.
weld and then take the torch back to the area welded.
after a bit you let it sit in the BBQ for some more post heating and then step the temp down to cool slowly
bob
tonydanzah
the champagne of people
It also depends on the quality of the cast. I successfully migged a decent quality USA made vise. I didn't preheat just welded vary slow to get the heat up and used the vise for years with no problem. I tried the same technique with with an overseas made vise, the weld cracked the first time I went to use it.
P
peterj
NC
Thanks everybody - Had never heard of preheating or postheating, I will find a welder based on your advice.
38Chevy454
Cincinnati, OH
I am a metallurgical engineer. Here is why welding cast iron is so difficult.
Cast iron has approx 3-4% carbon (C). Regular mild steel is about 0.1-0.2% C. Iron (Fe) and C combine to make iron carbides at the right conditions. Iron can only have up to 0.8% C before it has to form a carbide or be free carbon in the iron matrix. Most cast iron is grey iron, because it appears grey on the fracture surface. The grey is because it has flakes of carbon (graphite) in the iron. Flakes do not make it stronger or help ductility. Nodular iron has round nodules of C in the matrix. Much more ductile.
Any cast iron when welded will form the carbides at the fusion line. Carbides are not ductile at all. When the weld metal shrinks - ALL welds shrink - it pulls on the base metal at the fusion line where you have carbides and you get fusion line cracking.
All the techniques: preheat, slow cool, high ductility filler, peening after welding, are all attempts to minimize cracking. They all help. Brazing is used for a lot of cast iron repairs for the exact reason it does not form carbides.
rodm1
Keep it cold or hot don't let it heat cycle and tap the the weld with you slag hammer in between welds. Stainless filler.
porschedude996TT
Santa Maria, California
I have welded the bolt hole ears that protrude from the casting on a small block chevy head years ago and machined them on a mill. One other time I welded cast iron with no sucess, it was on a pool heater manifold. As soon as I hit the stick large pockets appeared. I ended up pre-heating the manifold and brazing with brass. Never tried to TIG weld cast iron, now that I have a TIG I may give it a try.
I recall an article about using a bed of match light charcoal to pre-heat.
Good luck with your welding project, and I hope it doesn't become carbon arc light.
dr_clyde
Holland, MI
well, to be honest, the high carbon content of cast iron makes it impossible to get a truly metallurgically sound weld. However, you can braze it very well. You can get a weld that will hold rather well with stainless, but the best way is to preheat with a torch, then tig braze it with silicon bronze rod, then postheat it. If you hear a tinking sound, your weld is breaking and you have a problem with either your preheat or post heat, depending on when you hear the sound. from the sound of things, you've already heard all this.
W-Cummins
Iowa
If it's worth the $$ take it to some one that welds cast iron all day. The best IMHO methoud to repair cast parts ( heads, blocks etc..) is to gas weld them with a torch. I took my last head ( cummins 6bta) to a guy that did nothing but weld cast iron engine parts all day for over 20 years. He heated the parts in a furnace until it glowed almost yellow hot, then removed it and placed it on a table with gas burners keeping it warm. He then welded it up using a triangle shaped cast iron "rod". After welding it went back into another furnace to cool slowly ( ramped down) over night. After it was done all the machined surfaces needed to be re-machined as the metal moves around, but you couldn't tell where the repairs were even done....
William.....
bayou985
S.E. LA. SWAMPS
If cast iron is not too porous Tig weld with 320L wire...If You find porosity at toe of weld.grind and weld over toe again...Hammer Peen and cover for slow cool...Clean,Cleanand Clean again the secret too all Tig Welding
rsanter
visalia ca
if you really need to save something there are places that do 'metal deposition'
they will grind out the weld and then so an electrical powdered metal deposition to build the area back up.
it makes it about as close to new in strenth and looks as you will ever get
bob
P
peterj
NC
Thanks again everybody - You guys are a wealth of knowledge and experence
I haven't found anywhere else but here.
PJ
