Looking to add a 50amp hookup near my detached garage for a camper. The garage feeder from house panel is 4 wire, and the ground/neutral are not tied together (didnt install the green screw)
Camper hookups are 4 wire, 2 hots, ground and neutral. The way I understand it, nothing actually uses 240 volts, just 2 seperate 120v, hence needing the neutral. Am I understanding this correctly?
I guess my question is, I should be able to just run a 4 wire feeder from garage to a pole at my camper with my 50amp recepticle and be good to go, right?
Thanks.
Sent from my SM-G973U using Tapatalk
Thanks.
