What is magnetic nut setter for?
Jacobson
What situation calls for this tool ?
dburner1988
I use them all the time doing dash work in semi trucks really nice not dropping screws down deeper in the dash.
Sent from my LM-Q720 using Tapatalk
lbpd716
California
okay - I'll say it - They are for setting magnetic nuts.
No, like dburner1988 said, they are really handy for holding onto stuff in tight to reach spaces.
unslow1
Illinois
I used one earlier today for putting garage door bolts in without dropping them everywhere.
MrSurly
East Texas
I wore out several of them (1/4" size) running ALL 3000 screws to attach all the metal siding and roofing on my shop. The 5/16" size I use for running a bunch of tek screws. They are a very useful 'extra hand' allowing you to stick the screw in the nut setter then just point and screw it in without having to bend down and use both hands to install each screw.
CR888
'Magnetic nut setter' kinda explains everything. Remember those times you held a nut over a thread with one finger then tried semi-sucessfully to turn it with a finger from your other hand? Well, these tools make that easy. Next thread: What does a screw-driver do?
redwrench60
East Tennessee
They have many uses holding nuts and bolts for easy starting with a drill or hex impact but the best use is for self drilling screws.
Flat Thunder Channel
I use them for the galvanized / painted screws in downspouts. Keeps the self tapping screw in the bit so they are easier install. Could be handy for any self tapping screw.
Copymutt
Colorado
Can’t be beat for repetitive jobs when chucked in a battery powered impact driver. Irrigation T bolt clamps for instance & of course metal roofing screws.
J
Jacobson
Ok, I guess that was a dumb question.
I usually just use the socket and some masking tape.
Cool idea.
But how is this used to start SCREWS ?7
Shed of tools
Northern Canada
Metal cladding siding roofing any construction crew has a bunch on I’ve put in thousands of screws with them **** when your lining up a sheet of tin with one hand drill in the other and your screw falls out.:willy_nil
Bigblockyeti
Upstate, SC
HVAC work , you'll wear a 1/4" version out.
When I was a tinner doing residential and commercial work, I only got about 3 months out of a good one. Doing under slab duct work was particularly brutal. On service calls, you'd often be using a 5/16" and 3/8" opening up a furnace or condenser unit.
Bert_
NW Iowa
Driven thousands of self drillers and zip screws with them. Good for pulling screws out of equipment also.
bwringer
Indianapolis
Setting nuts magneticly[emoji28][emoji106]
Yep, they're magically magnetically multipurpose -- they can also be used on bolts and screws as well as nuts!
And, get this: they can be used to both install and remove said fasteners!
That's, like, SIX FUNCTIONS! :thumbup:
I use the 8mm and 10mm metric versions all the time in repetitive motorcycle work like removing engine cases.
Downwindtracker 2
BC
I first encountered them driving trailer screws working on setting up industrial camp trailers. Trailer screws are a #8 sheet metal screw with a 1/4" hex head. You also see larger ones used on sheet metal siding. The magnet holds the screw. If you have a travel trailer, you Need one in 1/4".
jd_1138
NE Ohio
If you have to ask what a tool is for, you haven't worked on very much stuff. :) But seriously, yeah I can see a use for this when working in small places. I've had trouble screwing in fasteners in very tight places. You may not have room to put your other arm in there too to hold the fastener while holding the screwdriver, socket wrench, driver, etc..
And let's say you work in a production environment doing this stuff many times a day, that'd make it even nicer having these to help.
Negen
Seatltle WA
I use them all the time to set nuts. Mainly use 5, 5.5, &7 mm or 1/4 & 11/32. Used in electric equipment , LCD panel replacement, ac/dc power supply repair up to 2500 watt. Common use for electronic type work.
Sent from my ONEPLUS A6013 using The Garage Journal mobile app
Fluelikesymptoms
Midwest snow belt
I get the privilege of using magnetic koken and apex nut drivers everyday at work. If I werent so cheap I'd buy me a good set of them. The magnets are very good for nuts and bolts. We mainly use them because it makes the manufacturing process quicker instead of fumbling around with nuts and bolts.
The magnets do wear eventually usually the spring starts acting goofy, but they last a long time in an environment where its being use amd abused non stop all day
