BORING HOP YARD
The first car I did I had a buddy who owned a body shop come over and show me how to get started. He said about 10 times to make sure your fit everything and that's what I did, everything except the hood latch. Went through body work, paint and into final assembly before I found out the core support was too tight across the top and pulled some of the point of the core support out, resulting in a hood latch that didn't have enough adjustment no matter what. So I hope you can learn from my error. I also find that the hole made by the screw helps to see if you got full penetration on you weld.
Sometimes I will drill out the screw hole to like 3/16, hammer and dolly to make sure both pieces are tight to each other then back up the hole with a piece of copper, brass or aluminum pushing it to the back of the weld. "weld wont stick"
Your going to learn so great skills as you move forward.
Think about installing all the screws, get everything perfect, it is a GTR you know
Then when it comes time to weld it up take you time, look at each screw hole for the best way to assure the metal is attached as good or better when it was spot welded.
Again take you time. When I first started, I think the first 5-6 took by far the longest, once I got the hang of it I was done in a matter of hours. Set your old core support up and practice welding on it to perfect your welders settings and your welding process.
Look forward to your progress.
Greg
Greg
