wyliesdiesels
yes it should be grounded. are theyre any pre drilled holes in it for a green screw?
How do you get at micro inverters if they have an issue? You have to take panels back up? Nice job on the system.
Got my first full day of monitoring recorded:
The peak power reported is just shy of 4400w. The lab optimal rating would be 4800w for my system. I am at 11.5 degree angle and facing due west so... pretty good efficiency! Actually better than my pvwatts estimate.
And... looking at the SDGE metering report, it looks like The system is producing throughout the majority of the peak pricing hours, which was a goal for me. Not only that, but over producing compared to my use in the last hours of the peak. I think my west facing array helps a bit with that:
Obviously this is peak summer production so have to wait a full year to see all the seasons of production before I get too excited.
Congrats
My house is skewed slightly to the North West. So we had a choice of putting 21 panels on either the East or West Roof. (South roof full with 18 panels) I went with the West roof for that very reason - production in the later afternoon/early evening is worth more
PVWatts was way off for me. After a full year of production, to get the PVWatts numbers to match my actual production numbers I had to drop the System Losses down to 2%
You should register your system at:
https://pvoutput.org/
It's funny that your system peaked straight across between 1 PM - 3PM, I usually get a fairly smooth curve unless it's cloudy.
This is from today
so what is your ROI?
Yea today was cloudy so the morning wasn’t as productive. I was also looking at that flat spot and trying to interpret the data. I don’t think its clipping because the inverters should still have another 100w total and only one or two panels barely broke 300w. I am guessing that’s approaching the real world panel output for this particular configuration. So the panels just don’t fully supply the inverters at that point maybe? I need more data points to really understand.
20,000 kWh a year is worth about $5k using $.25 per kWh so 2 more years the system will have paid for itself. I thought San Diego electrical rates were even more expensive?
Are you aware there are two different way to 'rate' solar panels?
STC - Factory Standard Test Conditions is considered the 'Name Plate' rating
PTC - PV USA Test Conditions. Real World testing, factors in temp of the panels, etc
My LG panels have a nameplate rating of 330 watts. Real World/PTC rating is 306 watts.
There is a downloadable excel file where you can look up PTC ratings from the California Energy Commission
https://www.energy.ca.gov/media/2368
I just saw that my electrical utility - Southern California Edison, is asking for a 14.4% rate increase starting in January 2021. 'Going Solar' was one of my better decisions
