Want to get some info on some reproduction decals for my Baldor grinder. Matt- I’m attaching photos of 2 of the decals i would like to get. Hopefully you can help!
PM Sent!
This appeared to be a very simple label and I printed it, laminated it, and cut it out only to realize that the yellow is transparent and very easy to see through.
So back to the design and I added an opaque white background. This made the yellow stand out and not get washed out.
It looks subtle in the photos but it makes a big difference.
When applying a clear label you have to be particularly careful not to get air trapped behind or it will show up on the surface. The best way to do that is to spray some water on the adhesive side of the sticker (a thin film) and then once in place use a squeegee to push out the water. You can use a credit card or bondo applicator if you don’t have a squeegee. Press hard from center out and all the water comes out and you get a perfect application.
Here are some of my squeegees.
My favorite is the Universal #907 gray squeegee at the bottom. It has the right combination of hardness and flexibility so I can really bear down on it.
