nice work getting it apart. I have a feeling that set screw into the lead screw was someones bush fix... I've had a bunch of M3s and never seen one threaded into the lead screw.... that would make the lead screw weaker.....
I see that there should be a washer between the collar and the casting. Is that brass? Does it matter?
there is a bronze washer between the spindle and the jaw, not between the collar and the casting.
some people will add washers to take up backlash and retain the factory divot for the set screw.
wiltons were steel, so were reeds..... it doesn't matter.
Those jaws don't look terrible? clean them up, hone the high spots off, and see where you are...
I agree with outlaw.
Plus, unless you’ve already removed those 4 screws and reinstalled, I'll say that most old vises have stuck screws. Many of us have had to drill out stuck screws. If you can just clean them up in place, you don’t have to hassle with stuck screws. And realize that many vise jaw screws aren’t easily replaceable because of their unique shapes.
Clean up what you’ve got.
Thanks 2oolhound
Yes, that sounds like an excellent application for Fluid Film. I have an aerosol can of the stuff so it’s easy to just squirt it on something and smear it around with my fingers.
He wouldn't be able to tell! His fingers are coated with the stuff!![]()
I'm restoring my Columbian 804. It is a swiveling vise. I've read about using anti-seize on the "screw". Does this work well because I do have some? I also have Red & tacky grease but that is "tacky" and thus is the issue.
And for the area between the vise and the base it swivels on. What should be used there? Is anti-seize ok there too?
EDIT: And what is the red paint everyone uses? Brand and color please.
Ha ha!
I have been using the same aerosol can of that stuff for several years. A tiny squirt of it goes onto the surface and then I smear it around with my fingers resulting in a very thin coating. It dries and forms a protective barrier that works well for me.
I use it on garden and woodworking tools too. After cleaning and sharpening pruners, I smear on some Fluidfilm. Steel drywall tools and putty knives stay rust free that way too.
I have read reports of fellows who spray the entire underside of their car or truck with the stuff each fall to protect from road salt corrosion. That’s where you WANT it to stay gooey. The FF undercoating is a different product.
Thanks but what does it feel like to the touch?
.... but realize that anti seize on moving parts may lead to wear because of the particles in the anti seize.
Is this going to be an outdoor user kind of vise? .....
I wipe on a thin coat and it dries/hardens to a protective film. It feels like bare steel.
Another option is Boiled Linseed Oil. Apply to warm surfaces and wipe excess off. Depending on weather and general conditions, it may take a spree days or weeks to harden. After that it’s a nice rust inhibiting finish that slightly darkens the metal which looks good especially on vintage equipment. Some guys bake it on using an old electric smoker. I wouldn’t use your kitchen oven. The stuff has a smell that not everyone loves.
Some guys just spray on clear coat. That’s another option. But that may chip.
I personally would not paint any mating / sliding surfaces.
---Never prime or paint surfaces that are friction prone and need to move freely.---Primer and/or paint will just cause drag and will eventually ware off anyway.---Just grease or oil those surfaces real good and regrease or oil as needed in the future.I personally would not paint any mating / sliding surfaces.
That's a---Never prime or paint surfaces that are friction prone and need to move freely.---Primer and/or paint will just cause drag and will eventually ware off anyway.---Just grease or oil those surfaces real good and regrease or oil as needed in the future.
