What is this thing?
IamtheGerman
I found this on the curb. What is it?
Some kind of compressor?
Rileysan
Milwaukie, Oregon
OP if you could tell us that full name on the label Robbins & ...We could find out what it is.
Is the tag on the motor?
More often than not, a motor is purchased from a third party by a machine manufacturer and then sold with an assembly.
From the pictures, I can see a pump on one end. I would think it's hydraulic because it has a line in and out. Judging by the hard lines, I would guess it sat on some sort of tank that it pumped from.
I have NO idea what's on the other end of the motor. Perhaps an air pump? It's unusual to see a dual arbor motor used in this capacity.
MrSurly
East Texas
the motor is a Robbins & Myers 1/4HP (?) single Phase 1750RPM 110/220 5/2.8A
MrSurly
East Texas
I THINK it's dual-head vacuum pump.
And maybe one head quit working and was abandoned.
O.P. can you give us pics of each *end*?
I'm betting there are labels or markings on the pump sections.
woody 73
The Great State Up North
Robbins & Myers make pumps out of Dayton, Ohio if you can type in the model number on your tag then search their web-site it will tell you what it is.
930dreamer
Amarillo,TX and Stinnett,TX
The only thing worse than me picking stuff up off the road- is friends bringing me stuff they found on the road.:dunno:
Is that a quick connect fitting in pic 2?
MrSurly
East Texas
I’ll say it again. It’s a dual-vacuum pump.
I’d bet at least a bent nickel on it.
txvwnut
Bedford, Texas
I don’t see an unloader valve so I don’t think it’s a pressure washer. The fittings say refrigeration to me as they appear to be brass or copper and single flare. Hydraulic would be steel and look to have a little more bulk to them.
MrSurly
East Texas
In addition to the flares it also appears to have a ‘service’ valve.
Old Man Roger
Palm Coast Florida
Ok this might be too easy. Take off one of the lines and see if there's oil in it. I still feel like it's something to do with water, maybe part of a car wash or something?
Lwel9226
So Oregon
I agree with txvwnut .... the fittings look like refrigeration to me....
I also think 1/4 horse motor would be too small for hydraulic pumps....
LynnW
