hardner for Rustoleum
toplessHO
central florida
whats everyone using for hardner for the oil based Rustoleum?
I ususally go to the auto body paint store and buy universal hardner,but now looking for something I can pick up at tractor supply,walmart,NAPA etc.
astroracer
Mid_Michigan
Any enamel hardener will work. I have used both automotive and "tractor paint" hardeners with excellent results.
Mark
Graham08
Iron Station, NC
I have used the Majic brand hardener from Tractor Supply with Rustoleum and it works OK. I have had mixed results when trying to spray the stuff. What do you use to reduce it and how much do you typically add?
astroracer
Mid_Michigan
I spray the hammered Rustoleum's a lot. I use Xylene to reduce it and generally follow the instructions on the can for reduction ratio.
I sprayed this custom chassis with silver hammered, reduced with Xylene and hardener added, it was rock hard in an hour.
ng8264723
Oakham MA
I use the tractor store hardener all the time. It works awesome. I really don't spray mostly I brush rustoleum. I usually add a capful to a small cup. I know not scientific
matt_i
SE Michigan
I used the TSC majic brand catalyst hardener added to rustoleum enamel. And a little drippy drip of mineral spirits so it flows a little easier when brushing. I mix it in a cut-off McDonald's recyclable drink cup. It does not seem to attack or affect the plastic.
For successive coats I lightly scuff with 150grit to give some tooth and wipe away any imperfections from the previous coat (bugs, dirt, drips, runs). Then a mineral spirits wipe on a huck towel. Then paint again.
This is a part I just painted.
aka Larry
Eastern, NC
I use the TSC Majic brand catalyst hardener as well with good results. I don't measure it, but for a pint sized spray cup, it doesn't take much.
matt_i
SE Michigan
mannydantyla
LFK
I've used enamal hardener and painted an entire truck with Rustoleum, enamel hardener, and mineral spirits. I wouldn't do it again though. After a few years of 100% direct sunlight, the dark green paint started to fade.
http://dannix.net/node/58
Earp69
What ratio do you use for the hardner? Also what primer do you recommend
T
toplessHO
central florida
astroracer
Mid_Michigan
I use the same ratio recommended for regular automotive enamel paint.
Epoxy primer is my go to for big stuff like chassis and underbodies. If you are doing smaller stuff Rustoleum's grey primer/surfacer is perfect.
Mark
Rlfd213
Looks good mark. The paint isn’t to soft or doesn’t mar easy?
astroracer
Mid_Michigan
No, not at all! The hardener makes it rock hard in a very short time. It is no where near "soft"... Without the hardener it can take days for the paint to set up and get hard. The added hardener speeds up that process greatly. :)
Graham08
Iron Station, NC
Mark
OK, so you're mixing at something like 4:1 (paint:hardener). I've been doing 16:1, which is recommended on the can of hardener (8 oz can to 1 gallon of paint).
I used Summit's house brand epoxy primer and chassis black epoxy on a couple projects in the last few months. I'm happy with how it goes on and it's not terribly expensive, either.
driftpin
I have poor reading comprehension, what does astroracer say is the hardener he uses? What's the in-between time for successive coats? Do you need to mix a new batch of paint for each coat, or can you mix enough for say, two coats, and leave it in the cup or a vessel you can seal, like a glass jar, if brush-painting? Thanks.
astroracer
Mid_Michigan
Any enamel hardener will work fine. You can get some at an auto paint supply or any farm supply that carries paint. Just ask for an enamel hardener.
This depends entirely on the hardener used and the amount added to the paint.
The hardener is a chemical reaction. The reaction is based on my above answer. Work time is generally 1 to 2 hours if mixed according to instructions. It will harden the paint if you leave it set so only mix as much as you can use in one application. :)
Thanks.
Mark
E.rodz
st.paul MN.
i have used just about every brand of enamel hardener and have had good luck with all. the ratios that work well are adding 4 oz of hardener to a qt. of thinned mixed paint i use xlyne for a thinner for average temp and humidity acetone for cooler temps and or higher humidity.you still need to be careful clearing over if you clear it an hr later it will wrinkle everything up.i normally let it dry for a couple of days before spraying clear on it.
T
toplessHO
central florida
It seemed like the stuff Ive used before(used for rustoleum and john Deere enamel)
was a 20:1 ratio.
But couldnt find any old cans to refresh my memory,hence why I started this discussion.
Good info from all,26 posts and I dont think one persons feelings were hurt. Is this a GJ record?
Earp69
was a 20:1 ratio.
LOL you might be onto something
pamike
Central PA
I have written on my hardener cans 8:1. I have done that and it works well. I think I researched quite a bit at one time to come up with the 8:1
RotaryLove
St. Paul Minnesota
Hey y’all, I figured rather than start a new thread id continue on with this one.
Last year I painted the rear cab wall and front bed wall of my truck with hardened rustoleum, with quite good results. I’d like to do it again, however this time using most likely hammered black on some RX-7 subframes.
Does the hardener improve resistance to solvents such as fuel, brake parts cleaner, etc?
shortykorte
Tallahassee, Fl
Found this video. 5 parts paint, 2 parts acetone, 0.3 parts Valspar hardener.
And an update to above.
Sounds like depends on temps and what’s being painted…..and what works.
Bennylava
Cleburne, TX
All of this stuff is news to me. I thought paint had to be created to work with a hardener. I didn't know you could just "harden" paint that was sold to be stand-alone.
So is this all tractor and paints made to be used on metal? It would this also work with oil based house paints?
MAD
Western MA
Recently, I used the Valspar hardener with PPG MAE single stage enamel on some body panels for my wife's Elantra with great results. The PPG hardener was expensive and the smallest size was a pint, so I took a chance and tried the Valspar I had on the shelf. I think the Valspar hardener is discontinued now. I wish I would have bought a few more when it was available and cheap.
Bennylava
Cleburne, TX
How did you guys figure all this **** out... You must be chemists. This is all wizardry to me. Using hardeners on regular paint..
