Blind bearing pullers
AmericanMechanic
Anyone know if there are other sizes blind bearing puller to match Proto 4280? Looks like thats the only size proto makes. I see an OTC American made set for $500 and a bunch of import knockoffs. Thanks!
Jbullfrog
Avoca, Iowa
There are numerous sets out there. I would venture the OTC set is rebranded for the tool trucks. Search "blind bearing puller set".
AngryBeaver
Lake Milton Ohio
I have an import knockoff set that cost me 40 bucks I think. It is identical in every way to the OTC 4581. I bought it because I was going to have to modify it for removing a blind one side opening bearing in blower cases and wasn't speeding 500 bucks to experiment with...
Packard V8
Spokane, WA
I'll tell you the one not to buy - Snap-on A78.
We've got one; $208 and it's never yet been successful in pulling a pilot bearing.
jack vines
Steve_P
I have a 20+ year old set from HF that works and hasn't broken. I only use it every few years but it hasn't let me down
B_Bimmer
Eastern Iowa
I have the old version of the otc 6981, it has pulled everything I have ever attempted, which has been quite a bit. It is an amazing tool and if I would replace it immediately if it were ever stolen or lost. I also have made several different yolks for it as quite regularly something narrower will fit better. It is an amazing tool.
Bondo
Greenfield, Maine
Ayuh,...... A grease gun, 'n an appropriate sized dowel is what I use for blind bearin's, 'n bushin's,.....
Pack the pocket with grease, insert the dowel, 'n Wack it with a BFHammer,.....
Kenstone1
Cheap white bread is cleaner than grease...
just sayin'
bob15
Northeasten, CT
Maybe for a pilot bushing on a SBC, but there are plenty of spots where you cannot pack it with grease or white bread and push out the bushing/bearing due to location or application.
Steve_P
Blind bearing pullers are specifically for removing races for tapered roller bearings in blind holes. Bread won't help.
Edit: there is no room for the typical puller jaw thickness in this application . Like what's shown above for pilot bearings
A
AmericanMechanic
And what size hole and ball are you going to use? Not to mention the pressure screw, are you going to make that as well?
Might be easier and cheaper to just buy what you need.
Don't know what ball you are referring to. If I build it myself, yes would make the threaded spreader as well.
bob15
Northeasten, CT
You would be better off buying them.....or at least one to understand how they work before attempting to make one. How do you think they expand when you put the expanding rod inside the collet?
