FMC1959
Yup, another generator related question. (sorry!)
My biggest concern is getting big enough Kw, but as small that will do the job for budget.
There will be other small items I will add to the calculation later, but for now, my main concern is the continuous and startup amps or watts needed for my heat pump which is the AC now and does most of the heating in the winter.
I have a 3 ton Trane XL16i (model # 4TwX6036h). I have called Trane, VM only. I filled out their online form, once 3 weeks ago and again a week ago, no response yet. I asked the contractor, he sent me the attached pic and highlighted my model and went on to say that it would run on 14.75 amps and need 18 amps at startup.
When looking at the specs, does anyone understand where he is getting 14.74 and 18 amps?
My system is hooked at 240v (I believe) meaning 18 x 240 = 4320watts, so about 4500 watts should cover the heat pump, if I get a 10Kw (12Kw surge), I have about just over 6000 continuous watts for additional stuff I would like to run...does all this sound right?
