Picked up this vise (WILTON UNIVERSAL TURRET VISE ) a week ago and finally got the time to post pictures. paid $50, not sure if worth it. Did quick cleaning with WD40 to remove lose debris. The jaws are not so good but still usable.
However, there are some problems with the vise, not sure if here is the right place to ask. Better to ask before doing anything. From seller's picture I knew the L-handle to lock the vise is missing, but did not know the internals had also been changed. Could not check before I got home.
I believe the original locking mechanism failed, and the owner tried to weld it (Picture 4) and also used washers to lock it (Picture 5). The weld has already broken but the vise can only make 1/4 turn to one side, and I think was due to remaining welding burrs and dremel should be able to to clean it.
The problem is with the locking mechanism. I searched the internet and cold not find any picture showing what the original locking mechanism look like. Found an old post in another site and he replaced with aluminum bar with offset hole but I'm still not clear how this will work.
https://www.lumberjocks.com/topics/45012
The last picture is what the original L-handle look like.
https://www.garagejournal.com/forum/showthread.php?t=271403
Wilton does not make these parts any more, and according to one of the members here they referred him to GJ for repair solution. He had the same problem.
https://www.garagejournal.com/forum/showpost.php?p=5549086&postcount=2704
I had some idea in mind but not sure if it will work or not, and will post later. If some one has pictures showing the original locking mechanism, or any advise, it will be most helpful. Thanks in advance.
