snap on speed wrench question
94yj
fort worth texas
i have the 9/16 5/8 version but could use i need the next larger size up did they make it? please let me know thanks
bob15
Northeasten, CT
Not sure I have ever seen anything larger than 5/8 in person.
An ebay search showed item # 323910252522 with a 3/4 open nd speed x boxed end
bob15
Northeasten, CT
What are you calling a speed wrench?
I grew up calling them broken wrenches.
They make it easy to spin a brass nut off brake lines when you cannot quite turn it with your fingers.
ChevyEFI
Phoenix, AZ
I don't think I have seen double-ended with 3/4.
I do have a 12pt box / speed open SO wrench I'd offload if you care for one.
94yj
fort worth texas
thanks looks like the largest is the 5/8 and that is what i use them for is taking air lines off of fittings and such on semi trucks and trailers they make life so much easier in tight spots
BFHtime
I just checked a SO catalog and only mm was listed speed open and ratcheting box.
I suggest get a set of double open wrenches cheap like harbor freight and make your own. Trace the pattern and proportionally adjusted the size. Could probably do it with a grinder.
