Ideas for supporting the work surface on a Steve bench?
60ZF1kKWT7lzWw7p
back yard
I'm in the planning stage for a Steevo style bench for my home shop.
For the work surface, I'll be using some 1/4" plate that I have on hand.
The work surface will be sitting on rectangular frames a bit deeper than the HF boxes (28" x 44"), and welded on all four sides.
I'm worried about the work surface sagging in the center of that unsupported rectangle above the toolbox. Should I be?
What's the largest unsupported span you'd feel comfortable using with a 1/4" thick work surface like this?
If additional support is in order, does a 1/4" x 1" flat bar "floor joist" across that 28" span sound like a good solution?
Design constraints:
  • No wood decking under the work surface
  • Toolboxes removable from the front
  • Overall height kept to a minimum
Thanks!
bdbecker
Iowa
It all depends on how what you'll be doing on it. Light duty, typical garage stuff? You'll be fine. If you're dropping heavy items on it or doing a lot of pounding? Yeah, you might notice a sag over time. If it were me, I'd probably add a support just for piece of mind. A piece of flat stock would be my last choice for adding a support - angle, channel, or tube would give you a lot more rigidity.
nadogail
Coronado, CA
IMHO, repurposed pallet rack beams would be good bench supports.
This suggestion assumes you have a way to both cut and weld steel.
60ZF1kKWT7lzWw7p
back yard
This is the sort of talking-sense-into-me that I was hoping for :)
Now that you've said it, a length of C channel, oriented like a trough, is the obvious choice here.
The heaviest things I can imagine that I'd put on my bench are the occasional engine and/or axle housing.
Thanks!
lis2323
Thanks!
C channel should be oriented in the “C” position for strength.
PugetDude
Superstition Mountains, AZ
If you're constrained by design to a 1" deep, section I'd use a piece of 1" square tube- heaviest wall thickness you can find. My second choice would be a pair of back-to-back
1" x 1" angles.
matt_i
SE Michigan
So I looked in my steel catalog. For 1x1 ERW (electrically resistance welded - seamed) box tubing the heaviest possible gauge wall is 10 ga, which is presumably more rare than the common 11ga.
But looking at the box tube cross-section and how it bears load from a stiffness perspective, this is essentially a 1/4" x 1" flat bar split in half.....
Granted in the Iyy/perpendicular dimension the box tube is much more rigid than the flat bar.
So, personally, I wouldn't feel bad at all using the flat-bar on-edge if you have it in stock.
Sometimes pricing is weird --- lately the tubing has been cheaper than "heavy metal" as I like to call it --- 1/4" and thicker. So that may play into your decision.
tarmy
Nor Cal
When I built mine...I wanted a stiff top...but height was an issue...
Made a steel frame and laid wood on top of it.
lis2323
I built mine 37 years ago. 16 gauge galvanized steel cladding double 3/4” plywood. No probs either.
Handi angle shelving oriented to manufacturer specs for support. EACH 8 foot section has a 3500 pound weight capacity.
Ck1
I would probably weld in 1” angle in a similar thickness that you use for the other tubing and angle. Add as many as needed
yarrum
Fort Worth, TX
This one is old. I built the top from air-dried rough sawed rock maple that I milled and glued-up while working at Tyler Mill Works furniture factory in Athol Mass in 1975. It's 10' x 2' x 1 3/4"thk. It was originally a kitchen counter in my NH cabin.. When I left the cabin in 1978, I removed it for future workbench use. In 1985, I bought several 4" x 10' steel structural C-channels for a dollar a length because they had ben under salt water and were pitted. The first photo was the original construct and the second is recent augmentation to enable storage of my 600-700 lb lathe.
BTW that looks like a Woden or Record blue vise. I have a 1950's Woden shown in another post.
lis2323
Your bench is beautiful!!
That's a Record on my bench.
Here's a Woden on my welding table....
yarrum
Fort Worth, TX
Here is another table, originally built from the same C-channels in 1985 for welding and when bolted to the garage floor, for bending. I built larger weld tables fifteen years ago and retired it as a mill stand. Can't throw away good art.
lis2323
That mill stand is gorgeous. [emoji481]
yarrum
Fort Worth, TX
Here's my Woden 186/5 on my positioner - variable height and angle useful for grinding/holding
steel 35
Between the PNW and the Emerald Triangle
I was looking up at the light :lol_hitti
I put plywood under mine for a while, but the slag balls stuck to good to the stainless:D
csp
Franktown, CO
I think you'd have to try really hard to get a 1/4" piece of plate to sag enough to eyeball without a straightedge over a 28" span.
