Generic name for optically clear plastic film?
crazybrit
Portland, OR
Does anyone know the generic name for the optically clear self adhesive film that is used to make screen protectors etc?
I bought a hood for use inside my welding helmet that connects to my supplied air respirator. The hood is fabric and has a clear plastic visor sewn to the fabric. The visor came with blue protective film on each side which was to be removed before first use but if the clear visor becomes badly scratched, the only option is to replace the whole hood.
I always find welding crud gets up inside my welding helmet over time so I'm trying to find some of the clear adhesive protection sheets that I could fix onto the outside of the clear visor. I'm less worried about the inside as there is a gusset that goes around your neck which should keep crud out.
I was hoping I could find something that was 8" tall and say 36" long but I'm not sure what the generic name of the stuff is.
I'd like something that has reasonable optics so as to not reduce welding puddle clarity, to that end I was hoping to find the stuff that is used for screen protectors (application bubble nighmare and all that) rather than just a loose sheet of plastic that's secured with double sided tape.
But open to any ideas. Cheap ones even better ;-)
Thanks
Kev442
Wi
The clearest stuff I work with is called acetate. But its flammable as are all plastics, you sure you want to do this?
Kev442
Wi
I was trying to point out that the peel and stick plastic is very flammable.
But yes, to answer your question, I sincerely think you should sell your helmet and weld without one.
firebirdparts
Kingsport, TN
I would never have thought to say cellulose acetate is flammable. I’ll have to set some on fire to see what it does. It’s certainly not known for that. In fact George Eastman called it “safety film”. It is the clearest, I think that’s right. We used to get great stacks of it for overhead projectors.
InsanePyro
Oconomowoc, WI
It may be more fire resistant then say, a water bottle, but as far as I know all plastic is oil based and therefore flammable
C
crazybrit
Portland, OR
Please STOP.
The welding helmet shell is plastic.
The visor in the hood is plastic.
THIS IS A TANGENT
Please if you can answer the original question then feel free to chime in, else there are lots of other threads that need answering.
Sent from my MI PAD 4 using Tapatalk
InsanePyro
Oconomowoc, WI
Please STOP.
THIS IS A TANGENT
I have a welding helmet too. Welding helmets are flammable. Why do you think you occasionally have to replace the lenses? What could all the black specks be? Take a chill pill numbnuts.
Dustball
Hudson, WI
Thanks
Material similar to window tint film but clear?
Loose Nut Buster
Near my house in Houghton Lake MI
Looks to me to be a pretty light colored lens if it was designed for welding, I'd think its more like for painting.
A fan positioned near you and a good quality welding helmet that flares out at the bottom and fits against your chest is my suggestion, it works for me.
Are you welding all day on a job? If so I'd think your employer would/could assist.
Sent from my SM-T387V using Tapatalk
C
crazybrit
Portland, OR
Huh? The hood fits inside of an existing welding helmet and connects to supplied air.
Anyways i resolved question myself.
