Recommendations on 2 Jaw Pinion Yoke Puller?
bulletpruf
San Antonio
Fellas -
I'm in need of a good 2 jaw pinion yoke puller. Will mostly be used for Ford 9" rear diffs.
Anyone have any recommendations?
Thanks
Scott
ThePostman
Virginia
I have a craftsman 46903. 7 ton, and USA made, at least mine is, I've had it at least a decade. Works well and is built solid. Always grease the thrust bolt, on any tool.
bulletpruf
San Antonio
Get the kit off ebay thats the knock off of the Yukon kit.
I didn't see a Yukon kit for pulling pinion yokes. Can you be more specific?
That looks like the one I need, but they only ones I can find are on eBay for $100. Ouch.
Steve_P
OTC 4534 is nice; the cross bar is really useful. They also make a larger one
matt_i
SE Michigan
I made one once for the axle in an S-10. Just a piece of flat bar, lets say 1/4" thick for lack of a better recollection probably about 24" long. Actually I think I welded a square plate to something like a 1/4" x 1" handle.
Transferred the 4 holes, welded a fine thread nut, turned a point on a Grade 5 hex head, glob of anti-seize and I was off. The long handle helped me resist the torque of loosening the nut so the truck didn't run me over :D Was also useful when reinstalling it.
I ran over a plastic grocery bag on the freeway and it got wound around the pinion shaft, the thing had probably stretched out to about 1/4 mile long....I was simply amazed at how many "wraps of plastic" had gotten in and gotten hot and melted to the pinion seal and ripped it out. I try to dodge those stupid bags as much as possible.....
TOTO
Campbell County, Va
bulletpruf
San Antonio
I have had the Craftsman branded 8" 2 jaw puller for decades. Has done everything I have needed. Mine is #946903 but there is a 946905 version on Ebay right now (still says USA too)
https://www.ebay.com/i/174250956744...1291&msclkid=431a08e4848a131fe26357c8dec533e8
That's a good price. Made in the USA is cool, too.
This is what I ended up buying - three different ones.
Crazy story on the grocery bag! Never heard of that happening before.
The Tiger Tool looks nice, but didn't want to spend that much.
Advance Adapters looks nice. I ended up getting something similar for about half the price - https://www.summitracing.com/parts/rat-18002
