Qualitytools
In this case the ratchet has a separate spring and pawl for each direction, so I was able to swap out just one of the springs and compare it to the original by switching the direction switch.
I think durability is the main concern. Pretty sure that fitting weaker springs has a similar effect to adding years of wear/fatigue to the original springs.
Also, I think some/most people may prefer a more positive clicking sounding and feeling mechanism.
+ what mrspeed said.
Mr Lemons, First and foremost thank you for sharing your experiment. A couple points to bring up, a shorter spring may not be a softer spring due to the fact that it was cut. Second when you cut the conical spring did you cut from the larger end in order to maintain the proper collapse that you refer to in your post so that the coils collapse within each other rather than on top of each other?
