bad_idea
IN THEM is indeed my biggest concern. I regularly clean my shop with a leaf blower for all the dust that settles ON THEM.
That's really nice, did you make that? I'd like to copy it but it would be anything but quick. And probably not as pretty.
Hey Pat, I sent the plans to you via email for the air compressor hose and storage rack I made. Let me know if you get it ok.
Anyone else wants a copy let me know.
-Clint
I am searching for a good and compact wall mount for bicycles. The main problems are not a big garage and 4 bicycles need to be storageHave you any ideas on this?
I have more space along the wall, because extending away from wall is staying the car![]()
Assuming a standard garage height, ...
If only there was such a thing. There are new home standards and older home standards and really old home standards. It seems the really old and the new homes have the higher "standard" of 10-12 feet tall where as us in just older homes got stuck with only 8 feet "standard".
Sorry, don't mind me I'm just vent bitchin'...carry on as though I'm not here.![]()
Made one of these to hold drills and batteries while charging. And i am not a woodworker at all.
[/url][/IMG]![]()
Here it is mounted above the fridge, cuz you need a beverage while the battery refreshes.......RIGHT
Hard to see but mounted on top is a fused on/off extension cord strip. So i can just flip it off when it is not in use.
[/url][/IMG]![]()
I've built a few of these from the excel spreadsheet.
[/url][/IMG]![]()
[/url][/IMG]![]()
There's a spreadsheet? Do you have a link?
Thanks,
The Harbor Freight units work great. I have two in my garage. I didn't trust their rope so I substituted some diamond braid polypropylene from HD.I am searching for a good and compact wall mount for bicycles. The main problems are not a big garage and 4 bicycles need to be storageHave you any ideas on this?
Nice work! I really like that! Did you glue and staple or brad nail together?
+1 ! I want to do something similar.
what about something like this minus the bottom piece so they can sit in from the topI’m looking for ideas on storing 3 jaw pullers.
3/8” eye bolt is, so far, my best idea
but it’ll need to be cut and welded to some kind of backing plate.
Sent from my iPad using The Garage Journal mobile app
Piece of PVC with a cap on the bottom?I’m looking for ideas on storing 3 jaw pullers.
how often do you use them? i subscribe to the "more often used tools should be more easily available" rule. So, my pullers live in the bottom drawer in a toolbox and I dig them out when I need them - just a few times a year. Some still live in the blow-mold box they came in...
same here. beelsr saved me the trouble of typing.how often do you use them? I subscribe to the "more often used tools should be more easily available" rule. So, my pullers live in the bottom drawer in a toolbox and I dig them out when I need them - just a few times a year...
Thanks,
Pucman answered these questions but just in case it was missed I've a̶t̶t̶a̶c̶h̶e̶d̶* Linked the file directly ---> the spreadsheet in question. Change the inputs in cells B4 & B5 to update the sheet to your desired numbers.
That's the same question I was going to ask. They are easy to unscrew to break them down, and they take up so much less space in a drawer like that.
If I used them every other day, I like eye bolt idea, but you would have to lift them a long way to get them out. How about getting a solid eye bolt, cutting open the end, bending the ends out and up, and turning it into a fork? Same narrow support but easier to get the tool on and off. Then it would be a long-shank, narrow-opening version of this:
One of the most (or only...) organized areas of my shop.
Needed a place to keep my 12' & 8' ladders. The space above the garage door is perfect.. I also need to make some dedicated straps with carabiners here as well, not that that the ratchet straps don't do a good job tho..
Not like I invented or planned this but I love my cubby shelf I picked up at a garage sale several years ago for unusual stuff that doesn't fit have a particular tool drawer. Fits the rustic workshop thing I was going for with the garage too.
