Between 485 & 705 SQ/FT Mid-Century Moto Mecca Makeover
Choirboy
SE Iowa
I'm far from an expert, but my two cents...
Not being a masochist, I went with nickel-copper line for the brake lines in my old F250. Bends and flares as easily as copper but the alloy means it doesn't work harden like plumbing copper and can be used safely in automotive applications. Never rusts. A little pricey, but good stuff. Doesn't look as cool as polished stainless, though.
bunks-tj
Manassas Va
If you were to start a long list of things I don't need tractor would be pretty high up on that list.
Gregor
selfishly i had hoped this was goign to be a MF to-20, as i have one that needs some work and a step by step write up by you would have been a god send.
but this is cool too. as always, over the top. :rocker:
Best,
sakurama
Portland - the cool one.
Like y'sguy, it's the hot rodder in me that loves the look of hard lines, especially polished stainless steel.
As for tools, any good flaring tool will work but I find the Mastercool a nice setup. I have flares for double flaring plus all of the GM and most Chrysler and Ford fuel lines plus I purchased a set of 37* dies for it to use for JIC fittings.
I also purchased an Imperial Eastman manual flaring tool many years ago and it used to be my "go to" flaring tool until I purchased the Mastercool about 10 years ago. If you can find one of the old Imperial Eastman that would be my suggestion as the Mastercool is quite expensive and possibly a little overkill unless you plan on doing a lot of rigid tubing.
As for benders, I think the best ones on the market right now are the Rigid HD line.
Thanks Mike - can always count on you for an education. I can imagine that a sand rail with stainless lines would be beautiful. Clearly a 50 year old primitive tractor deserves that same attention to detail.
I love the design of the Rigid bender. Makes perfect sense. Hurts that it only does one size.
What are your thoughts on compression fittings vs. flared fittings? Are there any implicit advantages to flared? It seems like a decent compression fitting would eliminate the need for an additional tool - what fun is that? But I've gone a long time without a flaring tool and most of my brake lines are compression fittings so...
Thoughts?
You know I'm a masochist and I love tools.
I would love to have an excuse for a real tractor and I love the old Massey Fergusons. I got to drive the tractor when we would cut hay and I absolutely loved the old Ford that we had. While this isn't a "real" tractor it does have that same massive crank and slow engine that get work done. But it's no MF.
___________________________________________________
So I've had a CraigsList search for a Clausing Drill Press going on 3 years now. Running searches like this is something I learned from LiL Scorpion and it's a pretty great trick. I set a low price and then wait.
The Variable Speed Clausing drill presses are one of the standards - like a Bridgeport. In fact they operate like a Bridgeport in the way that they vary the speed through a tapered pulley that expands and contracts to change diameter.
When I got the alert for a Clausing for $500 at 11pm I immediately sent a text only to get a response that the number was a land line - that meant it was an older person and that meant I could call first thing in the morning. Which I did. This is a $1000-1500 drill press all day long.
I was out at his shop by 9am and he was quite the character. He rebuilds radial engines for bi-planes and I regret not bringing my Leica. Pistons the size of coffee cans, engines under tarps and a biplane on a rotisserie. He was very patient while I geeked out at the shop.
We used a forklift to put the drill press into the van and then Scott came by to help me unload - thanks Scott. I was convinced it was about 200lbs but I looked it up and this one is right at 400lbs. So I'm extra glad Scott came by as I would have hurt myself.
It's dirty but there's not a single mark in the table which is sort of hard to believe. I don't want to be that guy who drills into a pristine table so I'll be careful. Also, I removed the digital watch from the old one and put it on the new one. At this point because it makes people wonder. My answer now is that I'm part of a drill team.
The great advantage of this drill press is that you can easily and simply change the speed by turning the top hand wheel. I think this one is something around 150 - 2000 rpms and the ease of changing means you won't be inclined to drill aluminum slowly or steel too fast. It encourages good shop practice. Plus it's a beast.
The best part is that I turned around and sold my Rockwell drill press in 12 hours for... $500. That is one fantastic upgrade for a drill press.
At first I was a bit disappointed that it wasn't a floor model but then I realized that if I find a solid Lista or Vidmar cabinet that I would be able to use that space to store all the drills, bits and tooling for both the mill and lathe. So I suppose that it won't be a completely free upgrade but nonetheless it's pretty awesome.
I also finally got the heat treated swingarm back on the BMW and I swapped out to a much higher geared rear diff. It was a day where I was "that guy" with a flat the morning of, then the carbs were starving for fuel and finally the ignition quit on me halfway. I still had fun but I'm a bit pissed at the bike - or maybe the mechanic who's worked on it. This is the second time I've had an issue with the ignition so I'm curious what the cause is. My goal to make this bike reliable is not going well so far.
But I did get a new drill press.
Gregor
Modern Jess
Bay Area, California
Are we related, Gregor? :bounce:
Picked up this 60s-era PowerMatic 1150 a few months ago.
Modern Jess
This is exactly what drove my choice to get a bench model. I despise wasted space, and a floor drill press is the poster child. I've been building this frankenbench (from an old butcher block kitchen island) for the last several months. Metal base to hold stem casters, HF top box, and wooden frame reinforced to kingdom come. The legs are bolted to the tool chest, which makes it even more rigid.
The thing about this particular tool chest is that most of the drawers are shallow, perfect for 1" Schaller cups to organize the endless amounts of bits and bobs that are essential around a drill press. The drawers are deep (front to back) as well.
I'm almost done with the build, today as it happens -- just have to fasten the top on and throw some poly on it. Then I get to try to move the beast of a drill press onto it.
sakurama
No, you're really neat - you might be related to my sister though.
The thing about this particular tool chest is that most of the drawers are shallow, perfect for 1" Schaller cups...
I did not know about Schaller cups until right now. I've seen them but didn't know they were a "thing" especially one that I needed.
Damn you Jess!
I think it was Jack that did Lista cabinets. I've resisted because of the cost and also the scarcity. I have found Stanley Vidmar's (oddly because someone put a wanted ad on CL for Lista or Vidmar) and they are a bit easier to find but seem to be the same quality.
I hope to find one like yours with shallow drawers so that I can now get Schaller cups...
Sigh.
Gregor
PS: nice job on the cabinet - that's hurricane ready. Or maybe earthquake ready in your neck of the woods.
Modern Jess
I'm not. I just hide the messes well. Though these long pandemic days, I have mode significant progress on making the shop tidier and more functional.
Damn you Jess!
Call me twisted, but I live for these damn-you moments. ;)
I think one of the companies bought the other. Dunno which direction. But presumably they're really similar at this point.
Schaller cups are a mainstay of the Lista / Vidmar secret cabinet club. I think Schaller even has specific configurations based around the drawer dimensions for those cabinets.
Thanks! And really, it could be either one at this point. Or both. Mixed with fire.
Bob Heine
Boca Raton, Florida
I'm new to Schaller bin cups as well. Rather than buy a couple, I bought the set of 49 1-inch cups from Schaller (https://www.ebay.com/itm/49-Schalle...e=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649).
I don't have any Lista or Vidmar cabinets and my HF 26" cabinet is full so I made a drawer to go under a soon-to-be-built workbench (termites ate the old one). Made the drawer from scrap wood but a bit too deep so it became a measuring tool drawer.
Scrap fencing became attempt 2 and it will go under a different bench with some full-extension slides.
If you like playing with a Rubik's Cube, these are the bins for you. The 49-bin set provides lots of possibilities as long as an open space or two doesn't bug you.
GeddyT
Bellingham, WA
If there's one thing I hate, it's going to the hardware store for a metric fastener and it not being there. We have this amazing old school hardware store in my town--the kind of place that's worth driving WAY out of your way just to visit once. The aisles are so narrow you have to walk sideways to pass somebody, there are bins and bins of random things tucked in odd corners, and the people who work there actually know their section and can help you. Everything about Lowes/HD, this store is the opposite. The store was opened in 1962, and sometimes you can dig through a bin full of widgets and find one in the bottom with a decades-old price sticker on it that the store will still honor.
Getting back to the point, this store used to be the only place in town with a decent selection of metric fasteners. I could even find metric well nuts on the shelf (usually used for fastening motorcycle windshields)! Over time, I don't know what's changed, but I find myself striking out more and more regularly, even at this store.*
I've gotten so frustrated with this situation that I've started dreaming about building or buying a cabinet and stocking it with a half dozen of every metric fastener known to man so I can leave the hardware store behind. I'll eventually reach the breaking point and do it, and when I do, an order of several hundred of those Schaller cups are going to be heading my way!
*At this point, I don't understand why any hardware store would stock any ratio lower than 80:20 metric:SAE fasteners. Is the understanding that people in the States work on nothing but Briggs engines or old Harleys? EVERYTHING is metric now. Hell, Fords are metric. When a Ford truck is put together with metric fasteners, it's time to rethink the inventory...
/rant
f121
UK
Thankyou for solving a problem I hadn't had time to think about yet! I need to build a strand for my bench drill (because it just got dumped on the bench where there was space), that looks like the perfect solution to get storage and strength.
Zippercat
TN
Damn you Jess!
Sigh.
Gregor
Pot, meet Kettle!
Gregor, you’re the guy who has pimped everything from fancy pencils to Festool to pizza equipment here-all stuff that none of us previously knew we needed-and now you have a fractional taste of what the rest of us have experienced!
smschriefer
Yorktown, VA
/rant
My advise is order from McMaster-Carr. You can buy bulk and pay what you would for just a few fasteners at the hardware store. I've done it with M6 and M8 bolts of all different lengths that are zinc plated and T30 button heads. I also have a wide assortment of washers and various types of nuts.
My goal is to buy those specialty pieces I use all the time and just keep a nice assortment. I can buy 100 M6x10 button head torx screws for for $13 in a polished zinc finish. I can't even get them at the big box store, but I know I'd pay at least $.50 each if they did have them.
zmotorsports
Northern Utah
Thoughts?
Gregor
Gregor, traditionally compression fittings are used for things that if a slight leak occurs it won't be a major issue. I usually tell people that compression fittings are quick and easy to use and for a non-critical component are decent enough especially if not planning on connecting and removing more than once.
For repeated connecting and removal of fittings or highly critical fluids and components I rely on the flared fittings. This is generally why brakes will have either double flare fittings or converted to JIC (37*) fittings. Hydraulics are usually JIC as well.
At work in the industrial arena we use mostly flared JIC fittings.
Also, great score on the Clausing drill press. I'm sure that you'll have that thing detailed out and in pristine condition in no time. Also nice to see the table isn't all full of drill bit strikes. I put one small one in my new drill press several years ago during a very small window of not being attentive to what I was doing and it makes me sick to my stomach every time I see it. On one hand I would like to get another table but on the other it is a reminder to pay close attention and treat my tools and equipment with respect. I may end up welding it and machining it back down but I'd rather to have not done it in the first place. Seeing that the older gentleman has a virgin table should say something about how he goes about his work and treats his tools.
Prometheus
Related to the Schaller bins - the drawer builder on their website is AWESOME. Put in your drawer dimensions and then you can drag and drop in whatever size bins you want. It automatically makes a list for you, hit order and you're done. It is deceptively easy to blow way more $$ than you'd think on bins though.... That being said, I regret nothing.
fartymarty
Fort Worth
I despise wasted space,....
Apparently not as much as I do, despite the beauty and craftsmanship of your stand, the space between the bottom of your BB top and the top of your cabinet is making my left eye twitch :wtf:. Maybe (likely) I'm missing something otherwise it's a great place to store your emergency bouillon perhaps, as long as you never need it. Or...you could use it to justify an overhead crane so you can quickly lift off that drill press to gain access.:rocker:
Regardless, now between you and Gregor, you two guys have me searching craig's list for a Clausing drill press so I can get rid of my "space wasting" floor standing chinese drill press that I was perfectly happy with until now. I'll probably thank you two a year from now, but until then...GRRRRR :mad::mad::mad:
Modern Jess
It's a necessary compromise. The HF top box has a space under the lid (which I've removed) but there's no good way to use that space, short of cutting the top off the box. Overall, I'm going to get tons of new storage out of the deal, and the drawers are perfectly sized for drill and machine tool type stuff. On top of that, drawers that are too close to a table top overhang inevitably suffer from not being able to get to the rear of the drawer. So there's at least a silver lining.
There's a small gap between the wood apron and the top of the HF tool chest -- I've considered using it for used razor blade disposal. I figure I could keep dropping blades in there pretty much forever and not run out of space. :bounce:
lilscorpion
Colorado
Noticed some of you guys who are using the bins for parts and consumable storage need shims to keep the bins from sliding around...
Had the same problem and it was driving me mad in my hardware drawers.
I use thick closed cell foam (this stuff is kaizen foam that’s about 2” thick) to cut spacers slightly oversized so they compress and lock the bins in place. You can also use larger pieces between the bins to shadowbox tools.
sakurama
Thanks for the explanation Mike. That's helpful. I have a flaring tool... and I had to go to the garage to see what I had. Imperial Eastman. I believe I got it from McMaster - this was about the time I came to accept that McMaster won't tell you the brand of tool they're about to sell you but if you can accept that you will end up with a really good quality tool. I'm still uncomfortable with the idea but I've yet to be disappointed with anything I've gotten from them.
And I ordered the Rigid tube bender in 1/4" so now I need to make sense of the wide variety of tube options on McMaster. What fittings and tube do you like? I mean, while I'm down this hole I might as well start exploring.
And this is what makes your thread(s) one of the most useful aspects of Garage Journal. Nice man, learned so much from you over the years.
Now I'm really excited to find that next cabinet.
Gregor
zmotorsports
Northern Utah
Gregor
Gregor, as for fittings, I use a lot of Earl's fittings these days but many times just whatever I can locate and haven't had any issues with any. Years ago I used almost exclusively fittings from Godman Performance and really liked the finish on them and the threads were nice without any burrs or sharp edges but can't seem to find them anymore.
I used Earl's when I built my sandrail and I was able to match all of them using fittings with the same anodizing but that was more for appearance than function.
zanyad
NE Ohio
rXc3NtR1c
The other thing to keep in mind is that if you're using stainless, then you will only be able to single flare due to the hardness of the tube. This is not really an issue however single flares are prone to leaking.
If you are using AN/JIC tube nuts and fittings also be aware that the 37 degree flare won't match up with 45 degree brake stuff if that's what you're doing. You can cinch it up a bit tighter and get it 'right', but again might be prone to leaking.
Tone
jimkinney
Florida's Space Coast
While I agree with all the comments about double flare and steel lines, keep in mind that this is a gravity fed fuel line, so almost no pressure. For this application, almost any fitting/tubing will work, but I think a double flare would be more vibration resistant.
You might also think about anti fatigue/vibration gloves for yourself. That thing is going to give you a workout.
sakurama
Portland is in the news a lot lately - mostly for the fact that there have been ongoing protests ever since the George Floyd killing. Those BLM protests have ebbed and flowed but what you see on the news is really just a 1-2 block area downtown. Fringe left antifa drew the attention of fringe right Trump supporters and chaos ensued.
While I fully support the BLM movement the news is dominated by assholes on both sides who honestly have no interest in anything but picking a fight. As you might imagine I feel like this sort of thing is down to lack of community. None of these people - like almost zero - are from here. They are drawn like moths to a flame by Portland's liberal image. Remember my post a ways back about the college riots? Trouble makers saw the chance to sew chaos and came from hundreds of miles away to do just that.
But so you know - 99.9% of us have nothing to do with those protests and it does not effect our daily lives. Just remember that when you see scenes on the news.
What does effect our daily lives has been the increasingly severe weather that is a byproduct of the global warming phenomenon. All of us here have had our homes and cars covered with ash from nearby forest fires and yesterday we had some pretty remarkable wind storms. Our skies have been dark orange as smoke obscures the sun.
And this happened yesterday.
A giant Maple above our house seemed to defy logic and gravity and managed to fall in the narrow gap between our house and the nearby trees.
It crushed the deck railing (we have always hated that deck) and missed the Ducati by a couple of feet. The paint got scratched by branches but that's about it.
It appears that the tree was diseased or weakened in the base of the trunk and I'm guessing that with the one half of the tree down the remaining is probably not long for the world and will need to be taken down before it falls on the house.
I always think it's really important to recognize your strokes of amazingly good luck and this was certainly one of them. Not only did the tree miss the house and the bike but maple is a great wood and I've been wanting to harvest a tree that I could use to make into a table for the dining room. This is that!
The trunk is about 24" in diameter so there's more than enough to cut to 8-9' lengths at the base and then take two really good parts from the middle and make a 4x9' table. Pretty excited about this.
Plus maple is amazing firewood so the rest of this tree will be enough wood for a long time. I'm going to need to make a wagon for the Gravely now.
So, our lesson for the day is that most of what we're seeing on the news is "squirrel!" that is purposely distracting us from the things that are actually important. Our current situation is like a magicians slight of hand - by watching the diversion you are being fooled.
Gregor
bdbecker
Iowa
Wow... that was a close one! One thing worth mentioning - it'd be take the time to give your roof a good once-over and make sure you don't have any damage from a limb sliding down the roof or missing shingles. When these types of events roll through, its easy to focus on the tree in the yard and forget about the roof on the house.
isonic
Ham Lake, MN
I am excited to see how you go about making a table out of this tree. I have a few trees in my yard that I would like to take down and make furniture out of so I am interested to see how you go about doing it. :thumbup:
sakurama
Yeah, the roof needs help. This might be the impetus to kick it high gear.
Me too!
Gregor
GeddyT
Bellingham, WA
I didn't realize just how big that windstorm was until reading this! I don't pay attention to the weather, so I didn't see it coming until I looked out the window and saw branches blowing by. This is way up 250 miles north of you.
The fires are everywhere. It's funny, as Monday evening, I finished rebuilding a battery pack for the kids' bike and plugged it in to charge in the shop. I was a little worried about the condition of the battery, even to the point of unplugging it from the charger before I went to bed to avoid a fire caused by overcharging. My alarm went off Tuesday morning, I let the dog out to do her business, and my yard was full of smoke. Having heard nothing yet of nearby fires, I was immediately sprinting as fast as I could on my hobbled foot to the shop, figuring that battery pick lit up: "Noooo! Not losing another shop to a fire!..."
I laughed pretty hard after the fact when I learned the real reason for the yard full of smoke. Then, a bit later, the wind started hammering us.
My in-laws live in East Wenatchee, and they couldn't even go outside Monday from all the smoke from fires in their area. My wife read just this morning that 330,000 acres burned on Monday in Washington, which was more than 12 of the last 18 whole fire seasons combined in a single day. California is, obviously, getting hammered really hard, too.
I have some choice language for 2020 as a whole, but I think it would violate community guidelines here...
