52 chevy chop and random projects
Iceman32
Hello all, my name is Chris and I'm a heavy equipment mechanic. Been a lurker on here a long time but after reading through Robert's shop thread I thought I'd post what his inspiration has caused.
I got this 52 chevy pickup from my first welding instructor when I was 18. He started the chop on it. I got in over my head and it sat for 12 years. After reading through some of Robert's tutorials I thought "that makes so much sense I bet I can do that"
So here's what I started with. I have a parts truck that is all twisted i can use for patch panels.
so first part was removing the inner panels and cutting out the roof section, figuring it would be easier to work the welds along the edge of the roof instead dead across the middlecd9d59a4b26c045c44853d9fd677bac6.jpg1c8da9834db4cd23eca4d5ae8f67b21c.jpgbe25a9451e74b1b18a60ae1ecf599fb8.jpg98b6a79b3c92dda89ea761e625d1ec42.jpg
Sent from my SM-G975U using Tapatalk
BORING HOP YARD
Boring Oregon
Hey Chris, that looks like a big project. I have been following Robert for years.
I have asked him questions on occasion and he has always been nice enough to respond.
I also follow him on http://www.allmetalshaping.com/index.php
I wished I could take a class from him so I could get input on my process from him.
Your cab looks like a good project with lots of skills you will learn.
Cant wait to see the progress, thanks for sharing
I
Iceman32
Thanks!
There was a damaged section of the windshield opening I wanted to get straightened out before starting to tack everything together4ab5381efc437575696a3495e169cbdf.jpg7ef3c19266ae1f4437774b677314ef33.jpg0206bd9b907743d45bc9f74167e6b236.jpg04e5aa7892b1e3c7fc57d4b41b398cc4.jpg
I
Iceman32
Getting it all aligned and tacked553baf7e263ae747d9d249655160f1f5.jpgb4c99029362bbc74ce1840eb4dc53853.jpg65bf1b41f9f3e3c903c939eaafcefbfa.jpg7d30a2db384f8f71c411813574aa9b58.jpg
I
Iceman32
Next part was fitting the two filler sections at the top of the door openings. The front portion of the cab had been stretched a bit from damage at some point, i was able to get it shrunk down and aligned with the filler piece. And finished tacking the roof panel3cae9799dfb625ca4aa9b9347728b57c.jpge07a8209fa151d16b0695c398ffb435d.jpg32a01070eb5297008334b31654cc1af6.jpg57c77d268895373c89d929c6661a4793.jpg45a08ebe09eff72b96ee0eed06093249.jpg
I
Iceman32
Thanks for the warm welcome everybody,
it's a lot of fun to be participating in one of these threads instead of just reading for a change. Here's some more pictures, now its just the slow process of welding and trying to keep it straight at the same time. Plus patching that damaged area on the upper windshielda530b0ef33717049cae09fd1aa477e18.jpg7931631d442adbc655ef6d9d0e73b70f.jpg861bdde1bb7ea432faa71848529c9552.jpg09f54bd46e4b65a70a91213140085535.jpgd3b750d3f988c1d323ec5c455b19ff39.jpg1ab3c6b4f1a36534542ddfad855df703.jpgb8fae06729ad16bbf8f1004833c9ab07.jpg
I
Iceman32
Spent some more time on it last night finishing the welds on the windshield patch and working on smoothing things out50db479172679072cce1a5f3326a5501.jpg2cecf3e13c79312fa3de4a56720b1fd9.jpgb5215ac642b7897c672d7dfcebd3ab65.jpge1cc835f73e11febb594e2276badcff7.jpg
I
Iceman32
Nice fab work, I always thought this type of work would be very rewarding.
Thanks! I really enjoy this kind of work, to me its a very relaxing thing. You can't rush it and I just methodically focus on one small area at a time
I
Iceman32
Started on the back of the cab. Measure, mark, cut, trim, and tack8b4788286df7450f562d698d0406cb20.jpg9948b5cdb9728d88c67dc74ce7bc187e.jpgd8ca76d29abd4935f44aa1f8ba9995a7.jpge5feb36918ec44d2d419217916529207.jpg4058a2bd4df37d13894cb19f87826377.jpg9854446ccbff16e885b4b7c80010529b.jpg83a63193281ba48e17f9aaa714a910b6.jpg37b64631f4509801e3f09559120a3670.jpg
I
Iceman32
It was a productive weekend.
I got the second corner tacked in place.
And then worked on the rear window, I didn't like the mail slot look with 4" removed, so I redid it only removing 2.5" I think it looks a lot more proportionate 096e0460b83a680919a693997853a836.jpg5a0dcad5f4bf83719fe0bb8c27e9e824.jpgb7c2bde7ccf2f066428e08f5ce55c79d.jpga3386399123053205e43aba8dc042852.jpg
MikeinNorthWales
SE Pennsylvania
Hey, Chris, that is some nice work. Good catch on the rear window. Now is definitely better than later! Make it look the way you want. I'm not sure I would have caught that, thinking it must be right because I took the same amount out as the chop.
I
Iceman32
Continued welding on the rear panels. 491cf76790eebbb9cc018d1f1e9d3ad7.jpg6ce77fdecb9145594d1d7894e51e50e5.jpgcdf4b9560ece56847c8178b248974b17.jpg
And a repair I did for a friend. He is a riding instructor and a student crashed one of his rental bikesc1d45991293c928cb24696db8d7cb143.jpg88015becd1b6d74986f072d9250e4501.jpg4a68465fbabcd0ae0cc49ed865cc6539.jpge9cdf0570933370fd8c94dc1a947ddae.jpg4275c83aec5be91246d21df5057c4308.jpg
I
Iceman32
Spent some time trying to clean up and smooth out some areasbc14724e2d41959bb9ac30dcd3d5a586.jpgcd30099db37fa243af20e23d7ba46775.jpg8b842326bebdf65eb7cf62f1113e82e2.jpge33d670d09762001fd2f0776df6e653c.jpg
I
Iceman32
Not a ton of visual progress. Just continued welding the rear window and corners. 8eb057b505fc428937a8a8c66983e737.jpgba8062ef541f674ca689c5d5439ead70.jpg39e81835723005cb8620be162c7319f7.jpg
Stooge
South Shore, MA
Very cool project and great work on the sheet metal! those advance design trucks are some of my favorites. Does the upper door frame/ sill have a little peak to it from the chop or just the picture?
Subscribed
I
Iceman32
Subscribed
A little bit, i have spme straightening to do still buts its more a visual illusion. I haven't welded the lower sill portion yet and there is still some paint so the grinding marks make it look a little wavier than it is95e31c5e1a62fe4b490f1d8f76f8627f.jpg
I
Iceman32
Filled the filler neck hole in the cab.baad9799571918db4fcbf98c893c1835.jpgb05778d1c7d1ab4c4565bf582b268add.jpg69579d57c9d2832b14acde382f6df281.jpg doing some more finish work my da sander locked up. Dissassembled and found the bearings are shot, will have some new ones tomorrow.5ed0df23d4ba6295a074d1675e6d2d93.jpgd38fa51b722fefdd040702b319fba460.jpg
I
Iceman32
Fitting a Couple more patches7e8a26c3bf6d24fe451b7c3b75f06271.jpg48392d0404c9c0a45cace47497132e9b.jpg40937bc3cf0143af6d8cc5d0b939f458.jpg6d657ead8f16026d7b19f81897d29d03.jpg1fb2641a069f214bdd35b5cc9bb1ff8f.jpg386eb5352960594cd008c09c22bb449a.jpgdc3cad1fbaece1a39601ab108f500588.jpg06f05823e1f9c7b4a12fe450c4322996.jpg
I
Iceman32
Where the driver door Jamb was originally cut was pretty crooked, cut that section out and bent up a new peice.aed941cd99f2664e77999207028bfd17.jpga59b439c27296497d5ac55fdaae19f21.jpg
And continued smoothing out the previous welds 2349638c4ffece571b54d95292636284.jpgfdb021e1152753c5c733b974b3aa5268.jpg
I
Iceman32
Started work on removing the leaded seams 62b68c4b2d329c4cb77e9206e6e25818.jpg0442499f14434e8c75dc47d8a9f9c737.jpg5141b65bac1b60fd5e8e284ed44e61c3.jpgbc4a4519246d5843f5e8dae012663cd1.jpg5740ce96504955ed25349ce2d434c485.jpg70033352f8a4f6780366385bb94da674.jpgc93018b33f0d82123de17453a4f54150.jpgf2a0dbfddb6fef3aa2c206ed5e5a7625.jpg
I
Iceman32
Started cutting down the interior panels177ab63697645c9913d2278cf6725c83.jpg9b14610e4422eab06c4e98501bcd28f9.jpg1bdb4d5d0306db0e1c6f1e9a92221f25.jpg
