nsula_country
I was able to install the front drive shaft, but I failed to do basic engineering and due diligence regarding angles. I did the math on the rear and decided to run a double cardan given the angles, and just assumed that since that was already the plan on the front it would be OK.
Well it's not. I have onset of drive line bind at ride height. Angles are extreme, 26 at TC and 18 at pinion. There are a few things I can do to mitigate but the axle really needs the 'C's cut off and clocked about 8-10* to bring pinion up. This would require complete disassembly of axle and affects the position of all the brackets. Poo. Doable but a major pain.
The other option is to lower ride height and give up some up travel, and use limit straps to limit down travel. Coilover springs are already too long so I can't lower it any further at this time. I guess 'smaller' tires (38/39s) could be an option as I got these 40s used/cheap mainly for mock up purposes.
I set caster at 6*, so I can back that down to 4, and use a set of 2* ball joint sleeves to further move pinion up. This gets TC to 23 and pinion to 10* but only allows for 1.5" of down travel. Even if I lower ride height, down travel is limited.
Another option is a bluetooth front driveshaft like you see on Bro bling trucks at SEMA. A decent solution for the mall parking lot though.
Along those line the front shaft isn't needed to get motor started or first lap around the block so it's not really a blocking item. Just irritating and depressing, but that is how custom fab goes. Adapt and overcome.
The cross member does clear at ride height so it could be worse. May have to clearance at full droop.
ouch
There is also a horizontal offset that further eats into angles
OG Ranger and Voodoo for me too. Why mess with it?
Dude... ***** that geometry is biting the ***. Make lemonade!
Get it running/driving. Shake it down. If have to cut perches and reset (likely) so be it. R&D. Ever not have to re-do a capitol project at your day job? I have. But only once
...I'm not going 4x4 crawler, but show/driver in 6 month window when I pull trigger. Will have OS moments. That I will share with the GJ audiance that chooses to follow.
Good luck bro!
PS, got you to page 41
CT
