Hot Dawg 45K Heater Install
u3b3rg33k
in that case maybe go solar and a GSHP? longer ROI but you can lock in low rates for power for 20+ years :)
D
D45
NW INDIANA
I am very, very pleased with the current heater..........the old 45k was nice and cheap, but the 75k heats the shop up faster and honestly seems more efficient than the old 45k, since it runs less once the temp it up
Its time to time the valve and shut off the gas supply for it, and unplug it from the outlet
D
D45
NW INDIANA
Here are my costs then, taken from the original HD 45k install and I added and adjusted what I had to buy for this 75K intall:
Heater: $575.00
B Vent Kit: $63.75
New B-Vent Elbow: $23.80
Thermostat: $20.05
Tstat Wire: $8.00
Black Roof Caulk: $6.00
Clear Silicon: $10.00 (2 tubes, one for each install)
Wiring & Flexible Conduit: $15.00
Plug: $12.00 (1 for each heater)
Black Pipe/Flex Line/Fittings/Dope/Valves/Hangers: $405
Total: $1,130.60
Then, take off the $450 that I sold my old HD 45K for, and the new grand total for the install will be:
$680.60
I would say I am forgetting some small items here and there, but I know for a fact the total heater and install parts was way under $750
D
D45
NW INDIANA
Early time to fire up the heater, but I had to last night
Turned on the valve in the basement, the valve near the heater, and plugged it in to the outlet
Fired right up and within 30 seconds, the heat was blowing
D
D45
NW INDIANA
Coming up on March 1 soon, and the heater and setup did great this winter
As time and funds allow, I would like to research and look into some sort of insulation under the roof sheathing
I have open rafters that I like having and use the space for storage
I also have soffits running the entire length of one side of the shop, and also 6 roof vents...........so I am certain I have a lot of air circulation and heat loss, which I would like to cut down on
D
D45
NW INDIANA
Several local businesses have quoted me a price on spraying the roof deck
$2.50 to $3.00 per square foot is expensive!!!
D
D45
NW INDIANA
Turned the gas valve on in the basement
Turned the gas valve on in the garage
Heater fired right up
D
D45
NW INDIANA
A tad under 5 months later...……..think spring is here
Both gas valves turned off and the heater is turned off
Honestly was a mild winter, short of a few stints...…..heater worked great all winter
D
D45
NW INDIANA
Fall is here.........turned the gas valve on in the basement and the valve on in the garage
Unit fired right up...........ran it for 20 min just to make sure all is good
Showkey
"MEMBER EMERITUS"
Wausau WI
You tell it’s fall with all the Garage /shop heater questions.:dunno: 32* this morning :wtf:
D
D45
NW INDIANA
Yes for sure! The outside temps dropped to 39 here last night
My garage was still 58 this morning......with no heater on
Mainiac Mat
Maine
I just read this whole thread and the lesson learned for me was .... go bigger.
I did a heat loss calc and planned on using a 45K BTU. But since I will not heat continuously and want a faster heat up from cold iron time, I'm going to go with the HD60.
LPG for me... so I'll install and vent and wire and then have my friend the licensed gas tech hook up to the bottles.
Happy trails...
D
D45
NW INDIANA
I do not have insulation on the ceiling or roof deck........I use the rafters for storage
Installing vent covers/caps on the six vents in the main shop really seems to help with heat retention...........I will find out more this winter
950ish square foot shop attached to a 480 square foot shop
The 45k took too long to heat up the main 950 sq ft area and was running too long at that
The common wall for the other 480 sq foot shop (fully insulated and fully drywalled) only has windows and not a door. On occasion I open the windows to get warm air in the other side
My goal one year is to remove the windows and install a man door
65GTOTRIPS
I swapped the tiny sheet metal screws shipped on the brackets for some beefy bolts. I didn’t trust those little screws...
65GTOTRIPS
I’ve got everything setup to fire-up my new 60K HD...I changed it to propane with the conversion kit. I’m a bit nervous to start it up...it’s all vented, gassed, and electrically up to snuf...
D
D45
NW INDIANA
Coldest morning since last winter
Temps dropped to 23° outside and garage stayed at 43°
Looks like the 6 vents caps are working
65GTOTRIPS
❇️ Hot Dawg 60K Heater Install - Flame quality question
🟫 Hot Dawg - Flame color
Hot Dawg 60K Heater - Flame tips yellow OK❓
Hi’yall,
Just fired up my 60HD with propane conversion kit, and input gas is 13.5 H2O inches and I adjusted the outlet to spec at 10 inches H2O...
My question is...Is it OK to have blue flame with just a tinge if yellow at the base of the flame, turning to mostly yellow down in the exchanger tubes❓
The manual indicates it’s OK to see some yellow flame if there’s no soot.
Besides replying here, I’m perfectly OK to have anyone text or email me directly. I have to spell out my email because the rules say I need (5) posts to do that.
Dave Larkins
Call/Text: (610) 842-7905
Email: 65gtotrips (At) gmail (DOT) com
rlitman
Long Island
Re: Hot Dawg 45K (NOW 75K) Heater Install
Got a picture of the flames? LP does have a more visible flame than NG, and also requires more oxygen. So if you take an NG appliance and swap it to LP without adjusting the venturis, you may get a yellow to orange flame.
A lick of yellow here and there should be fine with LP (less so with NG). Dust in the air can cause that for one thing. But enough yellow to create any soot is certainly bad.
65GTOTRIPS
Hiya,
Yea. I did begin a new thread too, just figured I’d piggyback here cause there’s alot of great input...Thanks
D
D45
NW INDIANA
Yeah, but it's always nice to bump a good old thread...
I appreciate it!
I was a cool install and I am glad I did everything myself
I don't mind others on this thread at all, just feel that starting your own thread with your own title sometimes gets better/faster responses
D
D45
NW INDIANA
Gas valve on in the basement, gas valve on in the garage, power connected to the heater
Fired up and working great
$750 total investment and was a DIY project
Showkey
"MEMBER EMERITUS"
Wausau WI
D45,
How's your gas bill doing with the new heater compared to the old heater?
Thats back to BTU’s or BTUS’s discussion* size for the heater is more about run time …….gas is sold by the BTU ( therm) so the size of the heater should have little effect on the bill.
* other threads created many discussions on the size of heater, time to heat the space up some would argue fuel cost would be higher.
This year the propane and Nat Gas are significantly higher…….so bills might be 30-100% higher year over year.
D
D45
NW INDIANA
D45,
Can't really tell a difference
The 45k ran, and ran alot
The 75k brings the temp up much faster and doesn't run as much
So it's a trade off I guess in gas consumption
D
D45
NW INDIANA
The fan size and motors also have different amp draws, but as with the natural gas, I haven't noticed any additional electric consumption
The 45k uses a 10" fan
The 75k uses a 14" fan
45K AMP DRAW: 3.7
75K AMP DRAW: 2.5
PoorUB
Fargo, ND
A properly sized heater that runs longer cycles to heat the space will consume less fuel than a larger heater. How much difference? Hard to say, perhaps a few percent, probably to little any of us here without scientific test equipment to tell. It is pretty hard to compare one years heating bill to the next as the outside temps and the wind are not the same.
It surely is not a huge amount, maybe 5%.
D
D45
NW INDIANA
My main attached two car garage is not heated, however its fully insulated and drywalled
According to the garage door opener pad (has a digital temp readout), the temps never drop below 47
There was a furnace vent running in to this area, that I plugged and blocked off
I think the duct work going to the vent radiates some heat to keep the temps up
I have a a shared common wall with this main (original) two car garage and the garage/shop addition. This wall has two windows............I am going to crack both windows open an inch or two and see this winter how the temps are affected in both garages
The roof vent plugs are still in place in the shop addition
D
D45
NW INDIANA
Fighting the urge to spend more money on this project, even though it works flawlessly
Thinking about upgrading my $20 low temp thermostat for a wifi tstat
Turn it on while I'm driving home or turn it off from inside
Just ideas
Showkey
"MEMBER EMERITUS"
Wausau WI
Fighting the urge to spend more money on this project…….As a side note:
Focus on Energy project sponsored by many power companies is selling NEST T-STAT for $4.99 with free shipping.
  • Like
Reactions: D45
PoorUB
Fargo, ND
I have the Honeywell Redlink set up in my house and garage. I worked for a wholesale house and got the set up for free when I went to a school. A bit over kill for a shop!
You can buy a WiFi 'stat for $100-$150 that will do what mine will. I set mine to 55F and I can bymp up the thermostate from a computer or cell phone. My shop is detached from the house so it is nice to turn up the heat an hour before I go out there.
D
D45
NW INDIANA
What wifi thermostats are low temp rated?
I keep my tstat set at 55 and just click it to heat, to turn it on
