Monoprice--cat6 cable recall
AP514
Pearland, Tx
dogdog
You'll have to use a softer flame for the test, I think they burn differently... But any who, thought they have those plenum cables are for....
jeepxj
Monoprice will be providing inspection and removal services for the recalled cable and will provide installation of UL 1666 compliant replacement CMR cable, as approved by the CPSC, free of charge. To the extent you have purchased recalled CMR cable and have yet to install the cable, Monoprice will provide replacement cable. Please check your inventory to determine if you have the cables in stock or, to confirm that they have been in installed.
ooofffff. that is gona be a hefty bill if they moved some volume
56Mark
Fall Branch, TN
I watched the burn videos. Thanks to the guys that did that. I put in about 600' of this in, in November 18 when I was building a house. Almost all of it is pulled through the attic and now buried in spray foam insulation. There are a couple of places it goes down the wall and one drop all the way to the basement. It was mostly for POE security cameras. After watching the videos, I plan to.....do nothing. Where I have it pulled, if there is an ignition source big enough for the cable to burn and contribute, I think the whole house will be a loss.
jkeyser14
(rural) Maryland
That's a lot cheaper than paying for a building that burns down.
I dunno... In my house they would basically be gutting the entire interior and refinishing it. I have a minimum of 4 jacks per room, and another 8 run up to the attic for security cameras in the soffits. Some of it is run behind my shower wall, kitchen cabinets and appliances, etc.
wyliesdiesels
Modesto, CA
I read their recall, but I still can't imagine them paying to tear down drywall and repair it. That would be a huge bill.
yeah gonna be very expensive
the bad wire is not gonna spontaneously ignite. It would take an outside source to catch on fire. The issue here is the fire spreading...
A
AP514
Pearland, Tx
I am with you I would Do Nothing..I did the test on the cable and think what a waste of resources. the test probably showed an extra inch of burn. So, All of it is bad ! ! Call the President we have an Emergency.
Total over reaction if you ask me.
I might call them If they will just send me a new 1000' box without me returning the old. I am in :)
If so look out for some great EBAY deals in the future
dogdog
Same here.. :)
I think the Fiberglass insulation in between my walls those R19 burns faster than the cable... especially if you have the paper backed fiberglass insulation. Go cut a patch and try it with a torch....
But just saying if you are going to do a proper test, soft flame will make those jacket burn and catches fire, not a strong propane from a torch. Just saying your test might be flawed.
wyliesdiesels
Modesto, CA
Same here.. :)
Fiberglass doesnt burn
A
AP514
Pearland, Tx
Same here.. :)
Well, I might just put a candle on that test cable and see...good Idea :rocker:
southalabama
Brewton AL
In the world of liability,
They announce the recall, offer to pay full expenses,
Most people don’t avail themselves of the offer, ignore it,
Shtf - it’s on you.
Yeah I’d probably ignore it too but they counting on that. They notnplanning on everyone demanding full tear out and replacement
TuxThePenguin
I have 250ft of their CAT6 purchased in 10/2017. Should I use it? I see the recall goes back to 2018, not sure if this indicates the older stuff will be fine, or if that's just what they happened to test (or were somehow required to test)
It was only about $20, so not a huge loss if it's unsuitable.
Maybe I should do a little test on it myself.
dcg9381
Austin, TX
Well, crapola. I didn't get the notice, so I'm going to check the jackets. But I've installed at least 2500' feet of this stuff. I did not get a notice and I ordered directly.
They're not answering the phone number that they've provided - not a good sign.
Bad Habit
Chumstick WA
The recall is based on the cable not actually meeting the UL CMR requirements (how odd for an off-shore item...). Probably most of the use of their cable is for residential (only required to be UL CMX or higher. Chances are the cable exceeds the CMX rating, possibly even CM so it's more than likely fine. It's not like it's going to spontaneously burst into flames and spew toxic fumes, ala Bhopal.
A CMR rating means that it can be installed in non-residential environments inside walls, be run through non-air handling plenum areas and pass through floors in high-rises.
dcg9381
Austin, TX
Yea, I saw the actual burn tests. It doesn't look particularly flammable to me. The only case that I see as valid would be a high-voltage short (or inductive lightening) that causes the copper to heat up....
This is a big deal to me as I've 2,500 feet of this stuff in walls - easily. Once drywall is up, that's probably $30-40k in tear-out costs, loss of use of the dwelling, etc... Best case, substantial delay in construction until Monoprice gets someone out here who can do it. I've left VMs and sent email to them.
Edit: was able to get through to a person this AM - they have no record of me filling out the recall form - asked me to submit it again. Did confirm that my cable is impacted. Hung up on me, calls back either rang through or went to VM.
