bugnut
Tool post grinder will fix the mismatch in the four jaw chuck.
Nice to hear its mostly done and back to operational condition. Can get busy making parts on it now.
My little French lathe is still much the same, I have cleaned it some but it still needs a lot more cleaning and all the oil points will now take oil from an oil gun, which is nice.
I also bought a nice Bridgeport mill and had it moved to the workshop. Its set up and running but I need to shim it to level as the floor in the workshop is not great and all the oil runs out the left end of the table. It was £3,600 which is pretty much the going rate for a good one in my area unless you get lucky, I was looking for 8 months and it was really the first viable option. Since I bought it an almost new Taiwanese clone came up for the same money and a decent British clone (Beaver) from the 60's for £800, which is very cheap if its not worn out. But thats life, once you buy a machine more always appear for less money it seems.
There is a local ish job shop that closed and its all up for auction at the moment, 400 lots with the big machinery separate if they can sell it first, so I might be able to snag some tooling for reasonable money. They had some pretty big stuff in there.
I think I just bought the same cxa post.Well I was about getting ready to machine the bore on the bronze tumbler (bottom of post #163), but it's swing radius is 7". The Lagun will swing that, but not with a chuck jaw hanging on the outside. So, it was either pull the chuck, pull the gap, reinstall the chuck, machine, pull the chuck, reinstall the gap, reinstall the chuck or just do it in the Sidney and I can take it as slowly as I like. So I needed to get this thing operational.
I needed to make the CXA toolpost for the Lagun usable and preferably at the same height as the Lagun so I don't have to reset toolholder height. Ideally it would have a CA, but we don't have one right now.
I started with the T-nut, which which went well except for one goof. I didn't tighten the collet enough and was being greedy with a .730" deep cut taking the sides down in one pass and my endmill slipped deeper. I'm not pleased about it, but I don't want to remake it so I'll probably just fill it with JB weld and remachine.
View media item 106655
Then I made a stud. Nothing special, 3/4"-10 on the one end and M18x1.5 on the other. Single pointed. Went well. Clearly I'm much better with a lathe than a mill. I power tapped the block 3/4"-10 on the Royersford.
View media item 106658
View media item 106660
Now I just need a riser. I calculated the difference in center height between the two machines and looked for some suitable material. Didn't have any, but I we did have some old weight plates kicking around. I decided to trepan one out of the center. So I spent some time and ground up a face-grooving tool and tried that.
View media item 106665
It could have been a bit thinner, but it worked superb. Took almost all the rigidity the Lagun had to offer. I fed at 0.0045" per rev at 60 RPM.
View media item 106656
There's the ring sitting inside it's captor.
View media item 106657
Mounted up and ready to go!
View media item 106662
Center height came out perfect (at least up near the headstock) so tools are automatically on height for both lathes. I love that.
Rule of thumb is check it for level every couple weeks. It'll come .back. where'd you get your level? I need one.
Sent from my LG-TP450 using Tapatalk
Facebook Marketplace. Dad wasn't interested, so I waited for him to drop the price until I could afford it. He felt his old Starett no 95 was good enough. (It's not.) I ended up getting it for $80. Corner is chipped on the Phenolic, but otherwise it's perfect.
Here's the difference between his old one and the Lufkin.
View media item 106737
View media item 106738
As you can see the Starrett is closer to a Carpenter's level than it is to the Lufkin. I got both of our other lathes to within 2-3 tenths per foot.
Shoulda got the CA. Lol. Oh well. I never did come to agree with Doc on that. CXA is too small, cut and dry.
That Starret machinists level can be sent back to Starret to be recalibrated. I have two of them--a 6" and a 12". Both are spot on perfect, and I'd be confidend leveling anything with either one.
A quick way to check it is to note the reading and rotate the level 180 degrees. Both readings should be the same.
I... guys the levels are fine. The Lufkin is perfect and the Starrett is off by no more than a hair's width. We know how to calibrate them. The post was to show the difference in resolution and why the Starrett 95 is not suitable for leveling a lathe.
I thought I was going to do a real gnat's-*** installation and brought out my Pratt & Whitney Master Precision Level. Helping me was a millwright with forty years of experience at US Steel. He just smiled at my level and said, "Yer gonna make it hard on us, ain't ya?" He'd done countless large machinery installations and his take, a lathe as large as your Sidney is a dynamic device. Changes in temperature, humidity, large workpieces, continuous production, settling under the mounting points, will all move a big lathe more than the difference shown between those two levels. He said, "We can get it perfect on that level, but run it for a week, come back and it ain't gonna be where we leave it today."
jack vines
I can't believe that a Bridgeport costs so much in your area. Since England is so small and had such dense manufacturing to many years, I'd figure a mill would be pennies on the dollar! That is surprising to me. Sounds like your shop is getting tooled up nicely.![]()
-Oh sure, blame it all on me.
When we talked about that- and I thought most of that was over Turbo's Pacemaker- I'm not sure I'd picked up a CA yet. Maybe I did? Can't recall, I've slept since then.
I came across a CA, a real Aloris, for a pretty fair price so I went ahead and got it. Bought a couple blocks for it- cheap ones I could afford off eBay- but of course the machine wasn't even all in the same state at the time, and as of this writing, still isn't back together.
Just mocking it up, while the CA fits and should work, it may very well be a tad too big for my Springfield.
But, I have a giant compound (probably 10-15% bigger than the original, and even that's after I milled it down 10-15%) and had to offset the toolpost stud towards the front a bit, in order to actually have the tool hit the work before the chuck hits the compound.
The CA may alleviate some of that a bit. Dunno, holding fire 'til I get the whole mess reassembled.
Whichever one I don't use, I'll sell. I have half a dozen blocks for the CA, and closer to two dozen for the CXA. Pretty sure I can find some poor unsuspecting schmu... er, lucky individual to take one of them off my hands.
Doc.
jack vines
They are cheaper up north where the majority of heavy industry was, the biggest issue is old manual machines get exported, thousands have gone to India and China since the decline in industry here from the 70's the next biggest issue is space is expensive here so stuff that isn't used doesn't generally get left lying about, it gets disposed of quickly to make room, in my area which is rural and relatively cheap industrial rents are £6 sq foot per year and local government then takes another 49% of that rent value in tax. Since Bridgeports are still somewhat in demand in industry and are highly coveted in home shops (you will almost never find a bigger mill in a home shop here) any worth having are good money. A fully reconditioned Bridgeport can be bought for £13k.
At least used tooling is reasonably common and reasonably priced, though 40 taper is probably the most common and cheapest used.
I find it interesting how much location matters in such a small country. Then again, I wouldn't want to drive 500 miles either. I just figured it would matter less. Thanks for the knowledge, that's very surprising.
Beautiful work. Man i hope the Pacemaker doesn't need that kind of work...
Before:
And after:
And besides looking pretty... IT WORKS.
Congrats on persevering long past when most would have given up. Now you know your machine inside and out and can feel what is happening with it and know why.
jack vines
