Need some ideas for Ferret F70N saving
Shelbylex
I to restore/save old Ferret 70N
It was not holding position well and the direction level would not move easily. I took it apart and noted that the original grease became almost rock consistency.
I actually used a small knife and a screwdriver to start cleaning the gear wheel and the area. I did not remove the pawl as it needs to be punched out and I am afraid I might damage something. Tried to clean around with the pick. A lot of gunk came out, but some is still left.
What would you soak the parts in to clean it?
I have some WD40, PB Blaster, Evaporust... Was hoping to see if it will move better and possibly work well once all the caked grease will be cleaned out.
ATF sounds like a good idea to me, too. When you get that working, it will be a nice 1945 wartime example. Here is mine marked 1944 along with the rest of the Ferret set.
johninct
Gas, Diesel ,Kerosene . Be careful and do not remove parts if not necessary. On my Ferret, I replaced the bushing and barely gave it one more light tap and the whole top broke off. There must have been a micro crack in it. I was able to repair it to good working condition by solidering the broken piece back in. You can barely tell .
Shelbylex
Thank you, Oldtuleguy, d42jeep and johninct! I will pick up some ATF this weekend. I did a little bit more cleaning and it started working better. I hope ATF will help release all the dry grease which is behind pawl (I will not remove it given the advice)
Don, thank you for sharing the images, nice set!!!
Shelbylex
I would like to thank everybody once again!
I took it out from the ATF today, cleaned, put some superlube in and put together.
I decided to go with the two black non-original screws (one was missing on it and I decided to have both in the same color and used new ones)
It's unbelievably smooth now!!!
GalaxyRat
Florida
It turned out great!
Sent from my SM-G973U using The Garage Journal mobile app
