Jswain
Just acquired a new compressor which as far as I can tell has a 705 clone pump on it. Everything seems to be in good shape and the calculated cfm is right where it should be from the advertised values.
However I was wondering if the rebuild kits for them all are universal? Will the Saylor Beall 705 kits on eBay or anywhere else fit these clone pumps as well? I wouldn't mind at least having a kit on hand or likely going through it anyways as I use my compressor quite a bit.
Compressor is an 80gallon 5hp with the 705 clone pump, originally purchased from princess auto. Previous owner must have replaced the motor with a Baldor at some point. Paid $300 Canadian for it and spent another $200 on a new pressure switch/wiring/fittings/oil change and a 30a breaker.
https://photos.app.goo.gl/ucvhiUZZyoF426g87
