Marine heat shrink **** connectors
mrjaw14
Nashville, TN
I use regular heat-shrink **** connectors. I've never used the solder kind. I think the solder type is probably ok. If it's got the hot melt glue in it and you see it come out the ends I don't think there's a need for supplemental heat shrink. I prefer the crimp kind because it doesn't rely on the wire getting hot enough to take solder. I just have to crimp and heat it enough to melt the glue and shrink it.
No matter what, I'd be careful to use a proper heat shrink air nozzle, such as a butane torch extension with the curved tip on it rather than an open flame from a lighter. here's a picture of the type of kit I'm talking about. I use the long extension and the curved extension together. You can buy those separately and work on torches with the same shape head. Dremel also makes a similar kit that's cheaper than the power probe one. I think the heat shrink attachments are the most important consideration no matter what type of heat shrink splice you use
matt_i
SE Michigan
I use either Panduit or Ancor. Which are not solder-seals. But have yet to let me down in vehicle/tractor/trailer apps.
trashmanssd
Ma
I love those connectors. The colored part is the glue and solder in the middle. Just got to get them hot enough to melt without melting the wire jacket, aim the heat at the middle. I put one on a 14 gauge wire and put it in the vice and wrapped around my hand and I could not pull them apart. As long as you have the room on the wire to slide the up on side and twist the wires together those are the way to go. I still use regular pinch and heat shrink connectors for tight spots or double jacketed wires that I can't slide one those up though.
matt_i
SE Michigan
Are there concerns that if the wire gets hot due to short, unintended overload (etc) that the solder can melt out and go open circuit "?
rmack898
Honu Grove NE Florida
The only thing I use in the marine environment is Ancor, but these look interesting.
I'd like to do some side by side testing to see how they actually work.
sierradmax
Rhode Island
Here's a decent video. We all wish that fixing wires was this easy and not shoulder deep in an engine compartment soldering 1 wire within a 12 wire harness!
theoldwizard1
SE MI
Negen
Seatltle WA
I used these on two boats one fresh water and one run about boat that I use for crabbing and squiding in the sound. I use a good bit of flux and a in stranded 16gauge tinned wire. Some times I also use 14 gauge. In some situations I add a line of very thin solder about same size that's it's there I kinda just shove it in with the wires. I use a pen style portable solder iron with the torch tip .
I would trust these in recreational use in shore or near shore marine use. If applied correctly and tested regularly. If I were to go off shore I would be more of a perfectionist and everything would be perfectly over built. Boats for the most part do not rattle as much as auto applications so I am not sure if the cracking thing still is a issue.
The other option is the types of connections that are crimps with heat shrink same concept but with a crimp instead of a solder.Screenshot_Fennec_F-Droid_20201014-144621.jpg
Sent from my ONEPLUS A6013 using The Garage Journal mobile app
bpjr
Florida east coast
For cars maybe but...the ABYC (American Boat & Yacht Council) says crimp only and no solder. **** marine surveyors will note corrective action if soldered joints are found.
Mohawk Dave
SoCal
This is what I follow for off-road race truck applications. No solder due to vibration.
With that being said, everything is either WeatherPack or Deutsch anyway. :beer:
