D45
I have 6 roof vents and I would like to somehow temporarily add a poly square or insulation over them .......to attempt to loose less heat in the shop this winter
Any ideas?
Any ideas?
what size holes? I'm thinking plastic drywall inspection covers https://www.amazon.com/s?k=drywall+...refix=drywall+ins,aps,179&ref=nb_sb_ss_i_4_11
my neighbor did a foam spray on his roof deck and this negated the need for these vents all together ,, I would love to get rid of mine ,, i have probably 20
they let dust , and noise in unimpeded
I didn't ...... previous owners did
Oversize pieces of rigid foam insulation board with double sided tape around the perimeter.
Bill
Also, how thick of rigid foam should I be looking for?
Or does it really matter for how I am using it?
Menards has a variety of thickness and R values
1/2" (R3)
3/4" (R4)
1" (R5)
1-1/2" (R7.5)
2" (R10)
maybe just a louver on the inside so they can easily be opened or closed depending on your needs
I would use something thick enough -- ridged enough to stand on its own. Long screw with fender washer to the underside of the deck.
Buy some cheap roll of self stick foam and run around the permitter ...
My concern with the screws and a fender washer is penetrating the other side of the sheathing and causing a ton of issues
Bill
