have you used this yet?
I been eyeing it for awhile now.
Anyone else running the pole saw yet?
Very tempting, although an Echo gas job might be best.
Just bought the pole saw today. Opened the box and there were three pieces. The switch/battery base section, the business end section, and and optional intermediate extensions pole. I was looking around for other pieces (fasteners, brackets, whatever) but that was it. Just three pieces.
I took them out and screwed them together with the simple little threaded coupler that each section has. I snapped a battery in, mashed the safety and pulled the trigger. And it worked. It took 30 seconds.
I went out back and picked a 3" "trial limb" on the tree that's hanging over both my neighbors' fences. It cut through like butter.
I obviously don't have long term experiences to share but it sure was straightforward and simple.
Had it for about a month or so. No issues, not an everyday tool but gets the job done.
Have ran the pole saw thru several batteries cleaning up field ditch banks and tree lines. Also let two friends borrow. Nothing but good things to say here.
I freakingly love DeWalt and all the fools who love DeWalt and Craigslist/Facebook Mktplace/Letgo etc.
Last time I bought two fan kits with charger and 1.5 AH batteries for $59 each from Homedepot. I sold both in a day for $100 each. This time I got another bare tool (fan) from Lowes with a 3AH battery for $59. I don't know how much I can flip them. But $120 minimum. Last week, I bought a cordless, brushless XR orbital sander kit for $88. I sold the battery, charger and bag for $90. The sander cost me -$2. I just love DeWalt power tools. It is the perfect balance of price and quality, with a humongous rabid fans, fools or not.
So I just finished taking some stains out of the clear coat on the roof of my FJ Cruiser with my new DCM848... This thing is a winner. There’s a slight weight penalty with a 5.0Ah battery vs my old Porter Cable 7424, but it’s not noticeable on a DA because you have to apply some downward pressure on the unit to get some cut anyway.
Additionally, the weight is very balanced so I never felt like I had to “support” anything while working, if that makes any sense.
Not having to worry about cord management while running the DA freed me up to concentrate better on the paint surface. After about 10-15 minutes of run time the battery still showed a full 3 bars, so I’ll probably pick up a pair of 3.0Ah batteries on sale right now to make the working weight even lighter. I can’t say enough how happy I am with this purchase. [emoji106][emoji106]
The chain saw peaked my curiosity.I used the 20v chainsaw today for 3 hours, worked very well.
Has anyone tried out this inflator/deflator? I like the looks of this thing for taking to the kart track for the small volume tires on the go karts.
https://www.dewalt.com/products/sto.../20v-max-cordedcordless-air-inflator/dcc020ib
Sent from my SM-G970W using Tapatalk
sounds perfect for my use. Since I already bring Dewalt 20v drill and impact driver to the track with me, this seems like a no brainer.Yes, I use the snot out of mine for way more than small tires. I use it to run our 335/30R18 race tires up and down, take the truck tires back to 80psi before towing (run 55 on street) and on occasion have topped off the 110psi trailer tires. That last one takes a long timebut the rest are fine.
DaveW
thanks man, that makes up my mind.I bought one last winter. I use it a ton and its fairly accurate with the automatic shut off. I can't live without it now. The high volume nozzle is great for blowing up large floats etc as well. Before I bought it, I purchased a small 2 gallon air compressor just for tires because I got sick of waiting for my 30 gal compressor to fill. I think I've used the 2 gal air compressor once since I bought this and that was for seating the beads on the new tires I bought for my garden tractor.
Has anyone seen the new 20V tools with "Flexvolt Advantage"? It sounds like they run with 20V batteries but will perform at higher output when used with Flexvolt batteries. The increase in performance is significant so I wonder if they are simply drawing more current because the Flexvolt batteries can deliver the extra current at 20 volts or are the tools actually switching to 60 volts? I suppose the former would be just like the Power Detect tools so maybe it is the latter?
I think the math does support an increased output capability either way. A lower capacity battery (fewer cells in parallel) will suffer more voltage sag under load and will not be able to deliver the same current as a larger capacity battery (more cells in parallel) at the same voltage. Since even the smallest capacity Flexvolt battery has a relatively high capacity in the 20V configuration (6ah compared to 2, 3, or even 5ah for example), it should support a higher current draw, allowing for more power. All the tool would need to do is know it was connected to a Flexvolt battery and it would know it could safely draw more power without damaging the battery.I haven't... Sounds interesting but feels like marketing BS
A flex volt 2ah is just a 6ah 20v battery when used in a 20v tool. It is just math, no magic involved
I'm really tempted on the one handed recip saw during the free 5.0 ah promo
https://www.farmandfleet.com/products/1334532-dewalt-dcs369b-atomic-20v-max-reciprocating-saw.html
I got this Dewalt drill driver. (I really didn't need it, but what the heck this is garage journal) it's one of my first battery tools and Dewalt's first I'm thinking of getting an impact for Christmas.
I have been wanting this to replace my fullsize 18v one. If the deal is still active it might be the push to get it. Damn you lol.
