Show your new tool arrivals
16again
Boynton Beach, FL.
Kind of sort of a tool.
Toyota has a cartridge oil filter set up. All new to me. Ordered the tool to pull the cartridge 2 weeks ago. Ordered this drain hose when I realized, the real deal need for it!
Anyway, packaging for this was unreal.
Hope it works as good as the packaging. [emoji23]
16f96ef3a890eddcc11f0ee0eafa3f1d.jpg67c1b6886df9e90be1f26c29e2117835.jpg6131875f668a42bad677a896ce53484b.jpg
X1 Mike
Flagler, Fl
That's the type of box that I don't store the tool in but can't get myself to throw away but never actually find a use for the box and packaging. :lol_hitti
ddc9999
Why get a drain hose? I know you drain that oil filter cartridge before removing then cartridge, but the Toyota Oil filter comes with a small cheap drain plug you just push in. Maybe cheaper and/or different oil filter brands don’t come with that plug in it?
ForrestT
Waldo
Partially complete SK Tools 1/4 set I picked up today and Utica 50-8 Linesman Pliers and Channellock 436’s I picked up over the past week for $1 each. Cleaned up nicely. Just acquired the missing 1/4” socket from Roy this morning so will put it in place when it arrived.
16again
Boynton Beach, FL.
This one is thread on and reusable. No other reason.
qqzj
How much did you pay for the set of SK?
Sent from my Pixel 3 XL using The Garage Journal mobile app
dsimatt
Finally bit on tekton, pretty good quality minus the u iversal joint
z-edition 006
Norway
Snap-on THLL72
dede2897234
Northern, Ohio
dede2897234
Northern, Ohio
eBay
IMG_20201018_182230187 by david_edelman_ohio, on Flickr
IMG_20201018_182251886 by david_edelman_ohio, on Flickr
IMG_20201018_182334733 by david_edelman_ohio, on Flickr
IMG_20201018_181549669 by david_edelman_ohio, on Flickr
IMG_20201018_181641310 by david_edelman_ohio, on Flickr
IMG_20201018_165600253 by david_edelman_ohio, on Flickr
IMG_20201018_165700122 by david_edelman_ohio, on Flickr
woody6904
NW Ohio
X1 Mike
Flagler, Fl
I added a little Snap-On goodness today. I originally bought a used 15” long 1/2” drive dual 80 and had my guy put a new handle on it. Well to me matching is important and the rest of my orange fixed head ratchets were the shorter length. Of course the longer ratchet could not stay. S-O guy traded me straight up for a brand new SH80A which is the short 1/2” drive ratchet. Not too shabby for a 75 dollar investment.
PelicanPines
I had an old one of these... Ideal brand... battery exploded inside... damaging things. I tried fixing it... soldered in a new battery clip etc... but could not get it working...
NEW one works like a charm. Found out all my Garage Outlets are WIRED to the breaker labelled ... Garage Lights. At least they are GFCI...
javyLSU
New Haven, CT
:thumbup:
javyLSU
New Haven, CT
I've been looking at this, I have the old version... I like that the transmitter doubles as a receptacle wiring tester too.
PelicanPines
Big plus... the positive lights are GREEN. I have a few... one that I hate... the positive lights are RED and failure is yellow... WTF.
This worked more accurately than my old Ideal one too. I used to have to dial in the Ideal in addition to swiping all the breakers... this Klein... do a pass over all... then repass to nail the right breaker.
I really like the green lights.
I plan on getting the accessory adapters, for light build socket and non grounded and alligator plugs. If I ever need them... I will order them.
bsaint
Manchester, CT
Toyota axle nut combo set. Very reasonably price. Ordering my wheel bearing this weekend. cc496aac98b0137ead0e700e8d6949a0.jpg
dede2897234
Northern, Ohio
What do you think of the Astro 94404 spark plug set? Had the gearwrench version on my list after buying a 5/8 to try, but their set doesnt come with 13/16 which i use alot and I see this set does.
Hi woody6904,
I have yet to use the Astro spark plug set.
However, I do own the Gearwrench spark plug set with the 84 tooth bent handle ratchet. I also own individual Ko-ken spark plug sockets with the brass clips.
Out of the 3, I have used the Ko-ken and the 16mm socket. It was excellent in its use on changing the plugs on my former 2003 Subaru Forester.
This weekend, I will do a comparison all 3 makes. I will post the results and photos in a separate thread.
Dave
old_smokey
Manitoba
A while back I bought some Vessel power grip screwdrivers. I really took to them and decided to pick up some nut drivers, ball hex (purple handles), and torx versions (yellow handles). Very happy based on my initial impressions. All from Amazon Japan. Two day shipping and no duty charged.
Negen
Seatltle WA
This came today another Kline stripper pliers. K12065CR. Not sure what I think about these. The k12035 that I posted a few days ago would have been perfect if they had the crimp and no spring like these. But this pair the cutting edge is not as good and the stripper part seems less sharp. These do not strip at a angle like the 12035 do. Need more testing to see which I like better. IMG_MJL_%E2%93%82%EF%B8%8F-Canon-in-da-pocket-%F0%9F%92%A5_20201028_204236.jpegIMG_MJL_%E2%93%82%EF%B8%8F-Canon-in-da-pocket-%F0%9F%92%A5_20201028_204303.jpegIMG_MJL_%E2%93%82%EF%B8%8F-Canon-in-da-pocket-%F0%9F%92%A5_20201028_204337.jpegIMG_MJL_%E2%93%82%EF%B8%8F-Canon-in-da-pocket-%F0%9F%92%A5_20201028_204348.jpeg
Sent from my ONEPLUS A6013 using The Garage Journal mobile app
X1 Mike
Flagler, Fl
How does Amazon japan work? Do you have to make a separate account?
had a rough time reading it even when translated.
Qualitytools
SOCAL
Very nice, neat and organized. Thanks for sharing
old_smokey
Manitoba
I had to make a different account. There is an option to load the pages in English, but I find there are still a few bits that don’t translate. Overall I don’t find it difficult to use though. I also shop on Amazon.de for German tools. It’s not a guarantee the prices will be better, but in this case they were much cheaper than any domestic importer or even other Japanese stores. These ended up costing me around the same price per-driver as I would have paid for Husky screwdrivers at Home Depot. When I bought some Stahlville deep offset wrenches on amazon.de I saved almost $100 compared to Canadian retailers.
gatewaysysop
Arizona
Picked this up to go with my other vintage bar stool that I have out in the shop:
Admiral Chrome Corp. chair from the 1970s, near perfect condition. For a whopping $30 at the antique shop, how could I not? :bowdown:
toddmorr
Prescott, Arizona
thought I'd get some true JIS B 4633 standard drivers. From Amazon JP.
old_smokey
Manitoba
Whoa. These are nice!! I have some acetate handle Sun Flags as well for true JIS tips and they feel really cheap next to the Vessels. But yours look awesome!
M6erfan
'Merica!
I've had that Sunflag set for a few months, bought them last May from AMZN U.S. They're fine so far. Compared to my Vessels they're not quite as balanced as the Vessels but my Vessels are the non striking cap models (900 series).
WagonHo!
Albuquerque, New Mexico
from Toolnut
Makita E-01694 Impact XPS 8-Piece 1/4" Drive 6-Point Metric Impact Socket Set
$9.97
Regular Price $12.97
SKU E-01694
$3.00 OFF Instantly! Lowest price guaranteed. Offer ends 10/31/2020.
Ilikeike
Northern Ca.
That is a sweet old man chair.;)
I'm an old man and I need one with back support like that in the shop. :beer:
