andyvh1959
I finally got the four 2 AWG THHN cables pulled into the conduit through the garage floor of my new 24x28 garage. I'll have 220v 100 amp run to the garage about 35' from the house meter. I located the conduit to be just inside the sill plate before the slab was poured. The main breaker panel is about five feet up the wall above where the conduit comes through the slab.
I'm planning an outlet el body (pic below) on the conduit to direct the four cables into the 2x6 wall just above the sill plate. It is code approved to have the four cables go into the wall (eventually behind the OSB wall panel) and up the wall into the main breaker panel? Or do I need to plan conduit all the way up and into the main panel? I could install a section of OSB between the studs to shield the four cables before I install the OSB wall sheets.
