Craftsman Lathe
metaldad
nw indiana
Need some help, as to how the tail stock (?) would work on this lathe.
Short story, got it in semi payment for a side job, 35 some years ago. it's been moved from property to property, garage/shed/carage/shed. been wanting to make some oak legs. dug the lathe out, and actually looked at it for the 1st time. no craftsman id # on it, there's a bazillion entries on ebay. head stock (?) moves freely, as does motor. (i can get a motor anywhere).
work tube (?) is 45'' long x approx 2 3/16 od. head stock, 3/4x16rh thread. i was able to easily spin off the plate.
tail stock is where i need help. i understand use of the 2 clamps. one locks the assembly onto the work tube. 2nd secures the tail piece(?) tube to the assembly. round hand screw in the middle, spins with the internal work tube. (not freely). has a 1/4 x shallow (1/8?) keyway cut into it. tail piece tube is 3/4 od x approx 11/32 id, smooth bore. how does this thing work? and what do i need to get it functional?
took woodshop back in hs, forgot just about everything.
playing the crypt tetris game, i surprised my self, by finding, in the original boxes, 2 faceplates, sanding discs, and a set of seemingly new gouges. somewhere hiding are another pair of aluminum 'multi' pulleys.
motor was wired into an arrow hart overload type switch, i am not going to use it.
metaldad
nw indiana
saved
metaldad
nw indiana
saved 2
FrankLee
seMI, 48317
The tailstock tube has an internal taper. You need a live center in the tail stock and a spur point in the head stock to hold the work piece.
The slot in the tailstock tube should line up with the lock handle bolt so it doesn't spin. The round hand wheel is used to extend and retract the tube.
metaldad
nw indiana
damn, you are good! yep, taper, approx 7/16 on the other end, down to approx 11/32. some kroil, and the hand wheel spins, got the tube to extend from 1/4'' to 1 7/8. now i have an idea what to look for. thank you.
i guess i must have neglected those items, 35some years ago. dark basement. with a bunch of stuff. bucket full of old planes. a 10'' craftsman table saw i still use regularly.
and that is a nice unit you have.
metaldad
nw indiana
Frank, i have ordered, and received centers off ebay. they fit, ill start reassembly, and hopefully get productive with this machine. thank you for your help
