Help with hardscaping
ive
Canada
Hi all.
im doing a project at my newly purchased home. i have some pavers to install, a pad that will be going from the shed to the house. i have a problem, the house and the shed are not parellel to eachother.
does anyone have any ideas on how I can get a nice crisp look even though these 2 lines are not parellel?
thanks so much.
I
ive
Canada
Another attempt at the picture
I
ive
Canada
The pavers will be going between the house and the shed. You can see how the shed is skewed. Any advice on how I can make the pavers look real nice?
Thank you.
ace10
Rural NoVA
3 options than can think of...
Gentle curve. More work.
Straight line with the final course cut at a non90 degree angle.
I think the best option is to probably come straight off the house and then put one direction adjustment somewhere in the middle in order to line up with the shed.
You get to chose the exact spot of the direction change and will have the least awkward cuts.
Higgins
Shepheardsville, KY
Run the sidewalk straight but at an angle between the two structures. That way you only need to cut the starter course at either end!
AL
rjacobs
Dallas, TX
put a border around the whole thing and the herringbone in the middle.
Cut your border pieces to fit the angled shed so your herringbone pattern stays true.
OR: how big of a pain in the *** would it be to straighten the shed?
bczygan
DETROIT! Arsenal of Scrappers
Whenever I need to go from one place to another, especially for earnest errands like getting something from a shed, I want the most direct route possible. If a paved path didn't do that for me, I would cut across the grass and create a path with my feet.
So the solution here is to create an area of pavers in front of the shed, from which a paved path can go directly to the house. So something like this:
Bill
I
ive
Canada
Let me begin by saying thanks to everybody trying to give me advice. I truly appreciate it.
I
ive
Canada
Gentle curve. Great idea. I think that would hide it best? I’m gonna post a pic of where the pavers are gonna go.
I
ive
Canada
AL
Al, I’m sorry but I don’t understand. Could I beg on your patience to explai. This to me. Thanks!
I
ive
Canada
Shed is 10’x20’ with a 4” concrete pad. Has anyone here moved something like this?
I
ive
Canada
Bill
Bill, your logic is 100% correct. However there is a pergola between the shed and house. Wife wants pavers there.
I
ive
Canada
Here’s a updated drawing. I know it’s not nice, but I’m learning as I go.
RandyIA
Iowa
Is freestyle an option?
The way to hide a curve (not the best description) is to expand the outer course by a fraction with each brick laid. The inner bricks retain their nominal spacing. Assuming of course that there's enough room between point A and point B to create the desired effect without 2" wide gaps. However, this method would also likely not work since the assumed desired effect is of tightly fitted brick.
Another way to do it is to use broken brick, but I expect that's not the style the house and landscape would favor.
A third option is to use formed concrete with a brick pattern laid into the top with silicone stencils and colored dyes in the concrete. Done by professionals with a lot of experience the effect is nearly impossible to distinguish from real hand set brick patterns.
Nothing worth doing is always easy or inexpensive.
I
ive
Canada
Thanks so much. All ideas I’ll look into. Agreed, nothing good is easy.
I
ive
Canada
Nobody is going to ask how long it took, they will just look and say nice job.
RandyIA
Iowa
Hmmm...I'm one of those that bucks the trends...I'd ask how long it took. I'm also nosy enough to ask how much it cost. Not judging genuinely curious. Some folks can seem to do projects with very little money and make them look like a half million was spent on it. I'm always curious to know. But I'm also known for being blunt and having very few social skills. ;)
bkg
Mid TN
perhaps an overly simplistic question...
Can you adjust the shed?
I
ive
Canada
I’m looking at moving the shed. I’m wondering if digging it out the the gravel past the concrete and try to push it.
Do you guys think I can push it with a tracked bobcat?
RandyIA
Iowa
You said it had a concrete floor?
if so, you move it you might end up needing to pump concrete under it to re-level it assuming the slab doesn't crack and self destruct. Slabs can be moved, but when they are carrying perimeter loads it's not a great idea to do so.
K13
St. Albert, AB Canada
Straight lines rarely look good and rarely stay looking good especially up here when you get massive freeze thaw cycles for large parts of the year.. Curves are much more forgiving and look more natural in landscaping designs. Get a garden hose and lay it out on the ground and move it around until you get a shape you like for the outside edge of the path then mark it.
I
ive
Canada
True. I might end up with a big mess
I
ive
Canada
Great idea. Thank you. When I’m done I’ll post pics.
burleyfarm
Northern Michigan
My thoughts.
Straight and square pattern if your going for a modern look. Curved if more traditional.
I moved a 16x24 garage once by myself with a come-a-long, round fence post sections and my pickup truck. Jacked up the garage after I reinforced it with 2x4 bracing. Placed sections of large diameter fence posts under bottom plate. Attached come-a-long to the hitch on my pickup truck and some chain and ratcheted it to it’s new slab location. Moved it about 30 feet then had to spin it 90 degrees to set it up on the new slab. Once it was the on the slab, I installed a row of blocks to raise the walls above grade. Did the move while my wife was at work.
Point of this long story is that yes you can move your shed pretty easily if you give it some thought.
Dave
Justind97
Ottawa, Canada
I have an interlock company. Looking at what you are wanting to do, a good amount of square footage.
Leave the shed. I think you're over thinking it. Square the line of interlock from the house and run a soldier course/border. Start at the house, work your way down the outside then to the shed. Cut the border to run flush along the shed and don't worry about the angle, it won't be noticed.
If you have at least 4' between the houses, rent a Bobcat E10 and S70 and get it done quickly.
Go open a "company" with an interlock supplier. I prefer Techo Bloc. Nicest stones and fairly priced. You should get at minimum 28% off retail.
Interlock starts at $24/sq ft and goes up depending on stone and installer. Any cheaper than that, and they're not as good as they think they are.
Jayman17
Seattle, Wa
100% agree with this. Gentle curves look so much better in landscaping than straight lines.
Jay
TailGunner3000
New Jersey
I agree with the curve idea. I think if you also add some landscaping around the shed, you won't notice any difference in orientation. The pavers will border the landscaping, not the shed (except at the door) and hide any variance.
machsnell
Northern Virginia
What he said
Soldier course hides all and being out of parallel shouldn't even be a worry.
Do your infill with a mixed pattern of pavers
Sent from my SM-G960U using Tapatalk
