2020 Lowe's deals/sales/clearance thread
mikeinri
this is EXACTLY what I see on the "bargain rack" at my local store. The only thing I ever see with a deep discount is the most obscure fitting/bracket/hardware piece imaginable. Almost every item is a minor part of a larger system...unusable.
Or does that show the IQ of their customers? I think Lowe’s does that because somebody buys at those prices.
If it makes you feel any better, I see the same up here in southern New England. Occasionally, something decent will show up, but usually that's because the box is destroyed to the point they can't put it on the shelf at full price, or parts are missing. Even then, the "discount" price isn't remotely deep enough.
Slight tangent, but HF does something similar. They often have tool sets missing at least one piece. The discounts often aren't even as low a percentage of what's missing (e.g. one tool out of a 10-piece set is missing, usually one of the bigger ones, and the discount is less than 10%).
I don't know if this practice reflects the stupidity of shoppers, or the store managers who think so poorly of their customers (although, that may be justified if the stuff sells at the listed prices)....
Mike
DanielC99
Central Arkansas
No, that’s an anomaly at this store. They’ll most likely fix that.
I’ve found exceptional deals at this store. I bought the Worktunes for $19.95 a while back.
mikeinri
Really want to find that Worktunes deal around here!
It occurred to me earlier today that I comment here more than I post actual findings. So, I found a few things at Lowe's today...
The mailbox was about 25% off. If it were white, I'd buy it to have as a spare. We live on a curve, and the mailbox is on the inside of the curve, so it's an easy target if people aren't paying attention (I have a ton of reflectors on it).
The knife was also around 25% off. I don't really have a use for this style (I like the box cutter style).
The lights were a prime example of a joke of a discount. Less than 10% off, but marked as "Clearance."
Mike
Doohickey
You could call it the model that Home Depot uses, or just common sense. Though dropping (perfectly good) items to a penny and forcing them into the trash compactor doesn't fall under that thinking.
At least you can still buy clearance online from Lowe's (for now)
Are you still able to order clearance items with store pickup?
I have to now use the Lowe's app to view the quantity remaining at a store, but there's no ADD TO CART button for the item.
The Lowe's website shows the ADD TO CART button when using a store that is out of stock, but the START SECURE CHECKOUT button is disabled after switching to a store that is in stock. :wtf:
jimbos1ice
IL
Location Kankakee, IL
Prichman38
Kobalt 24” 40V hedge trimmer w/ battery and charger $34
I bought it just for the extra battery. Reg price $159
Location Kingston, NY
rexer
Earth
Lowes, Galdiator dual door cabinet mdl # GAGB28FDYG lowes sku #834694 is on clearance for $45.99 was $229.00
also 66" Galdiator bench mdl # GAWB66HWGG lowes sku #858949
down to $62.50 was $259.00.
Sorry no photos , but I did pickup two cabinets last nite..
Zestomite
Southern California
The popular King Kombo ladder is on clearance. It may be reduced more. It is being replaced with a one handed version (instead of two buttons). The one I grabbed off the stack happened to be the one handed version it must have been put in the wrong section. They adjusted the price anyway.
itlogus
Kobalt Compressor Tank Drain Hose
Item #896790 Model #SGY-AIR238
Mounted on Kobalt XC302000 using repurposed shipping bracket.
Reit38
Iowa
Anyone heard about the next Pella window sale? Need to replace around windows soon.
Think it's usually a 15% off sale?!?
Sent from my SM-G930R4 using Tapatalk
mcchazo
Anyone having trouble with find clearance item availability on Lowes website?
It seems you can no longer buy clearance items online, have to go to store. If that's your question [emoji2369]
Sent from my Pixel 4a using Tapatalk
jimbos1ice
IL
That definitely changes the game!
mcchazo
Even worse is when you find lower prices out of state ( not necessarily on clearance) the price at checkout will default to the price of the nearest store to the shipping address. So if I find a store in texas with a $50 grill and in NY it's $150 then it defaults to $150 :(
zeekh
Upstate NY
That would be alright if you can check inventory online but you can't ( easily) I use brickseek but they're not always right either
austinsec
Yes having the same issue too, keeps defaulting to NY always highter.
jimbos1ice
IL
Yea same thing with pricing some items you must add to cart to see clearance price which it won’t allow you to do. From the easy side of things it ***** because it was so easy to land some sick clearence deals however like sifting through Home Depot it’ll make shopping trips a little more fun. I’ve always enjoyed getting in the store and finding the clearence, I’ve gotten my best scores that way.
homeschool
W. Lansing MI store. There's also one of the compressor drain extensions left as of 0830.74489edbed886b1b670350574b650d8d.jpgfd4c370ab484498a9e9d6bd8b12ce5c0.jpg320597cf4a6e02279900c0631011bc05.jpg885f6e3cab69a1e0cb496417e218f22d.jpg5d06cdbbbf95b4085a71e0cbf912165e.jpgf8ffef30594ec5bf35a42ed553710afc.jpg0f0ba3e1a192c33e722406a0615e80a5.jpg567e8b04a6ff608737741c9d5a4379d2.jpg72a53fb98cf048cbe0c5cb93a18a1e4b.jpg
uncwstudent
MS
Thanks for the post on the SureCan. Picked one up today for $10 at my local Lowe's. Nice gas can!
FL-MEDIC-RN
Odessa, FL
I got lucky today at my local Lowes. They were out of the 2.2 gallon Surecan even though 13 were listed as available on brickseek. But they had marked the 5 gallon Surecans from $50 to $24 so I bought 3. Will be adding these to my hurricane prep supplies
Sent from my SM-N975U using Tapatalk
gilbo
You should check overhead, that's where I found the cans I got.
Doohickey
One of their Cyber Steals daily deals.
Dremel 125-Piece Steel Set Multipurpose Accessory Kit $9.98
Ship-to-store available.
mikeinri
That's pretty cool. Only thing missing is a cover for the whole set.
It should have a top cover (like a cake carrier) to keep dust and debris out, especially if you work near it with the Dremel tool. Any idea what size it is?
Mike
gilbo
Quick update, get them while you can.
Surecan 2.2 gal are going for $9.99
Surecan 5 gal are going for UNDER $14
hartlogan
Neither of these were marked down locally.
Still 30+ for the 2.2 gal.
Zestomite
Southern California
String trimmer and a cooler.
Bostitch 18g battery nailer is down to $44 if you have it in stock.
JP Chestnut
Upstate NY
I don't know if it has already been posted, but if you have a Visa CC through Chase they're doing 10% cash back at Lowes.
Reit38
Iowa
How does that work. I have a cabelas card through chase?
JP Chestnut
Upstate NY
I’m pretty sure it needs to be a chase visa, eg, “chase sapphire”. It works like any of the other rotating cash back deals. You go online and opt in and then it just works automatically. They just did a HD one as well.
