52 chevy chop and random projects
I
Iceman32
Thanks guys! Started on another side project. A buddy is putting together a backdraft cobra kit car. The fuel pump assembly was to small to fit the original hole in the tank so I am making an adapter plate1e2ecdee4538a1f08c6c8e331b8affd4.jpg first I made a template with blue tape1ed3b5cc8abbddaa5904c255cd2baac1.jpgthe outer ring is 5" across and the new pump is 2 3/4 so I marked center and layer out for the inner ring8274f67afbe3a230dc711edebb73f8d7.jpg26692cdcc8eee2e15048caf141ae83d2.jpg9762a8a29b3a3f4b00a46fcc7a34d73e.jpgthen pulled the tape off, transferred it to some plate, center punched and drilled0371e16d6e679bf340c69f0f245caa52.jpg9a6a7dfc42765d998d0324fab49b00b0.jpg
Sent from my SM-G975U using Tapatalk
I
Iceman32
Finished up the fuel tank modifications. Got the adapter finished and Made some mounts for a rear diffuser 064b811d398ef0ac260a0ad46775aa4d.jpg600a8a2d04914ac38d9b534220555acb.jpgf17bb1fae6141299a6ac00247f2e5155.jpg944cea8e1fdf37d17ef3ede41233b976.jpgdd953b2a39084471593a75b0c63c2f10.jpge4fa6dd43878c499999596ccea1ebe83.jpg
I
Iceman32
Well! It's been a busy month! My parents have decided to move into a smaller house after 32 years.. so that means I have to get all my stuff out of storage. Having a crane on the service truck made this all so much easier.
Got the truck and all the extra parts moved to the shop
And since I got all the extra parts to the shop I felt like seeing some more progress so I cut down one of the doors to get a visuale347b33b04b10ebe2496c26f61bd338f.jpg
Thanks for following along guys!
MP&C
Leonardtown, MD
Chris, I don't know how I've missed your thread until now, but I must say, you don't need my help for anything, truly some nice work.. And by now, you know that I'm a sucker for giving a good tutorial, and some of your work is a perfect platform for such. So please excuse me while I add some thoughts for anyone else planning on such an undertaking.. My comments will be in blue....
Hello all, my name is Chris and I'm a heavy equipment mechanic. Been a lurker on here a long time but after reading through Robert's shop thread I thought I'd post what his inspiration has caused.
I got this 52 chevy pickup from my first welding instructor when I was 18. He started the chop on it. I got in over my head and it sat for 12 years. After reading through some of Robert's tutorials I thought "that makes so much sense I bet I can do that"
So here's what I started with. I have a parts truck that is all twisted i can use for patch panels.
so first part was removing the inner panels and cutting out the roof section, figuring it would be easier to work the welds along the edge of the roof instead dead across the middle (highlighted for emphasis)
Compare the two views of the roof above. As you can see, once the roof skin is sliced down the middle all of the gentle, low crown support of the roof is gone. Just to the side of the middle cuts, the crown also loses some of it's support here as well, and things flop around like a wet noodle. So Chris' choice to use another truck as a donor, and keep this center crown intact is spot on. Any welds should be at/near the highest crown of the panel as possible, out near the corners, to help control any distortion and also to maintain as much of the center support as you can of the low crown in the panel. The seam running adjacent to or down through the center of the high crown is exactly where it should be, and the end result is less effort used in hammer and dolly work, and the low crown has been untouched, so it saves all that work to try and restore it..
Note the consistent spacing used in tacking the panels in initially, and then the beautiful TIG welds that follow. I think most people starting such an undertaking like this project will use MIG welding as we get our feet wet, and may or may not "graduate" to using TIG or OA gas welding. The above pictures show why one should strive for using TIG over a MIG weld. Nice consistent pass, MINIMAL distortion, softer weld for planishing, and for the full penetration weld shown, MUCH LESS weld proud to dress off.. As the after pictures below indicate, the panels still maintains the overall shape, no discernable warping/distortion, very nice work. Also note minimal to non-existent gap between the panels. Tighter fit-up means less movement when welds cool (shrink) and try to pull the panels together.
These views from the rear really tell the tale. All of the consistency in tight fitting gaps, tacks to hold the panels, consistent TIG welds, all come together when you view this from the back and see a nice balanced / symmetrical shape from one side to the other. Well done Chris!!
I
Iceman32
Thank you for the kind words Robert,
It means a lot coming from you.
And please feel free to use any pictures for tutorials or critiques anytime. If you can use them to help teach i would be honored
I
Iceman32
Goodness, the holidays flew by. Along with helping my parents move, I have been helping a friend with putting together a cobra.
Had some clearance issues with the headers
75105defb9ab21ad04925569573588b3.jpg so I cut and redid the rear most runnerf1a1605062a9e2a77e905526b634a4c5.jpg10a5b7a6a30185ba559d19719eeefde1.jpgf16659190355fb92c03dc59e5b751f0b.jpg10c1ad61e4bc94fe0ddf4cef0bc6281e.jpg
Jim greengo
Behind my house
I'm a big fan of 47-53 chevy trucks,not a big fan of chopped tops on them.
Looks like you're doing some nice fab work bringing that 1 back though.:beer::beer::beer::beer:
PWC Repair
Arkansas
Since you like the 47-53 style, check this out. Local guy built it. Split the whole truck in half and widened it to sit on an SSR chassis.......what the SSR should have been in the first place.
Moosefire
Detroit
Wow. That truck looks great. How much wider is it? Doesn't look that much bigger, but I'm no pro at looking at that stuff
Sent from my SM-N960U using Tapatalk
