Pulling Chalk line by yourself.
branimal
I just picked up a chalk line and was wondering if you guys have a hack on pulling it yourself. I'm a newbie to chalk lines.
Thanks
Toolfool
Tallahassee, FL
Chalk line tip : Pull the cotton line out of the chalk box and replace it with heavy test (75lb?) braided fishing line. When the cotton line gets wet, it stays wet. A hard snap will shake most of the water out of the fishing line. The fishing line will leave a sharper line as well, you'll get fewer snaps before needing to rewind and chalk up again, but the fishing line will last a looong time.
atch
Columbia, Missouri
The carpenter staff where I worked (when I was young enough to have a job) always used white chalk anywhere that would eventually get paint.
Beauregard
Southern Nevada Desert
When cutting plywood mark both ends of the cut with a pencil. Next make a 1" cut along your mark line then place the line in the kerf and pull tight. This works a lot better than hooking the funky metal clip on the edge.
