Fixing Your Flapper Valve
gahrajmahal
Cincinnati, Ohio
Bad things come in threes they say, and that is how I recently replaced three (3) flapper valves on three different toilets. I am not a plumber and I know that most GJ members are familiar with the workings of a toilet, but I am going to try and explain this so a complete novice can attempt this repair, so a little humor please…
Most homeowners have been tortured by this bit of toilet plumbery. The valve has two jobs.
One: to keep the tank of water in the tank until ready to flush.
Two: To release the tank of water into the bowl to flush away the contents.
It’s location? Inside the tank, clearly visible in the bottom of the tank once you take the off the lid. It is attached to the “Flush handle” by a chain typically. The flush handle is how the flapper valve is opened to release the water from the tank to the bowl.
The story starts off with an email from my elderly but spry friends. On their long list of broken things at their great 60’s mid-century modern home was a broken chain that lifts the flapper valve. Peggy, former engineer from Cincinnati Milacron, told me “I used sewing thread to repair it, because it was what I had easily at hand”. This was in a relatively new Kohler one piece, comfort height toilet I installed four years ago. What I found when I removed the lid was a 3” diameter flapper valve with a ball chain loop from the middle of the valve to the front edge and a foam float. I had a long length of ball chain from my garage stock and I replaced the “sewn together repair” (which was doing the job great!) with a new length of chain. Should have fixed it right? Well, no. I could not get the foam float to keep the flap open and “floating” while the tank water rushed down the open flush valve opening.
Problem: You must hold down the lever for a complete flush, or the flapper valve would slam shut resulting in a partial flush.
Looking online I saw that there are exact replacement parts and also re-designed universal parts. Back at home looking in my own toilet tanks I saw the float-less flapper design being used. The next day on my way back over to complete other repairs I picked up one of the universal no-foam-float designed flapper valves.
So here are some steps to completing the REPLACEMENT. First thing, find the toilet water-inlet shut-off valve. You may have some problems here if your toilet has never been replaced or serviced. Here in Ohio where I live we have very hard water, full of minerals, so faucets, shower controls, shut off valves all “harden up” or start leaking over a short period of time, 5-10 years. It will be difficult to turn off (clockwise) and you will probably need to use some pliers or a wrench to turn the valve off. If it is too difficult to turn off, STOP. Unless you want to replace the toilet shut off valve as part of this quick repair. If you can’t turn the toilet valve off easily, find the house main shut-off valve and turn off the water to the whole house. Not as convenient, but It will allow you to replace the flapper valve. This main shut-off valve is larger and more robust, so even if you need to use a wrench, you shouldn’t break it.
Using finger pressure, the old flapper valve will “snap” off of the horizontal pivot pins on the side of the overflow tube and flush valve assembly. I usually run my finger around the rim of the flush valve to make sure it doesn’t have a nick in it, which would allow it to have a slow leak. If so, then you need to replace the whole assembly and not just the flapper.
Snap the new flapper valve onto the horizontal pivot pins and you are almost home. Now comes the part where I received a “hands on education”. After replacing the flapper valve and connecting the provided chain to the outer most hole in the flush handle, I found the handle arm to be very short so that when in the open/flush position the flapper only opened to about a 45 degree angle. This results in the rushing water pulling the flapper back down immediately upon releasing the handle. This was the situation I was trying to resolve by replacing the float style flapper. My best version of completing a full flush, I adjusted the chain to have minimal slack and we resolved this to be as good of a fix as possible. It flushed well, but could have been better if the flapper angle could be increased. See my diagram:
G
gahrajmahal
Cincinnati, Ohio
Toilet #2:
So I revisited the toilet at my house where I did my flapper style research. I observed that it had a longer lever arm for the flush handle. This allowed the flapper to open to more than 45 degrees. I noticed that it also did not fully (2/3 empty) the tank when flushing, so I attempted to remove the slack from the chain. Doing so, the lever arm broke off at the handle due to corrosion!!! WTH? So now, I had to fix this toilet too! Back to the store.
This toilet, approximately 10 years old, was the “Phantom Flusher”. Not too long ago we occasionally heard one of our toilets flush. This usually occurred while sleeping at night because that is when it is quiet. Flush, Flush… What was that? I finally heard it flush when I was in the bathroom. What it was actually doing is the flapper valve and seat leak so the tank looses some of its volume. Then, the fill valve float senses low volume, suddenly turns on to top up the tank.
Your toilet can use a lot of water depending on how frequently this occurs. I removed the tank and replaced the whole flapper valve / overflow assembly. That is where the new style flapper valve came from (no external foam float).
G
gahrajmahal
Cincinnati, Ohio
Toilet #3
Well, Mrs. Gahrajmahal says “you know, the toilet in the kids bathroom is kind of hard to push down on the lever”. So, with my newfound “expertise” in the area of toilet flushing, I took off the lid to have a look. This toilet is approximately 8 years old and has never been serviced. I found a 3 inch diameter flush valve and a long actuation lever… but, the lever arm was very near the front side of the tank. This resulted in an odd angle for the chain to pull the flapper open, increasing the pressure needed to flush it.
Simple fix I thought (jinx). So, I removed the stainless steel actuation arm from inside the tank. Just needed to remove a stainless phillips head screw. I have a stubby ratchet that accepts screwdriver tips, so this WAS an easy job. I took the lever arm to the garage to clamp it in the vise and give it a little more bend. This will position the pulling force directly over the flapper valve.
And it did but… The force required was still hard to flush. Removing the flapper valve, it was completely made of white rubber. It was disintegrating and waterlogged, so back to the big box store.
Another 3 inch universal flapper valve and I was back in business. Now, toilet number 3 is flushing easily and with the correct volume. (I even adjusted the fill valve so the tank wasn’t over filling).
Now, if my friends with the original problem want a better flush volume without holding down the handle. I will purchase a new flush handle with a longer lever arm so I can increase the opening angle of the flapper valve.
Hopefully you might find some of this information helpful should you attempt this seemingly uncomplicated repair.
nadogail
Coronado, CA
Very interesting, some brands of toilet use a propitiatory flapper design. The Flusher Fixer Kits will fix most toilets, but not all of them.
The Kohler Low Boys, IMHO are a breed of their own.
PWC Repair
Arkansas
I installed an adjustable flapper on mine. It has a small airhole that let's out the bubbles for the flapper to close. As you spin the flapper the airhole effectively moves lower, letting out less air and staying open longer. I think it works great.
Glemon
NE
My mother has an old toilet in her bedroom, I swear I replace the flapper valve every six months (an exaggeration, but way too often). I have tried red, green, black, makes no difference, 70s house and godawful little cramped space to work in.
We have new Kohler's in our house, which I like, the flapper "valve" is a seal on the float that gets pulled up by the chain. Many years of service and finally had one leak. New to me, but replacement was a pretty piece of cake, twist the hard supply tube off, pull the float, pull the old seal, seat the new one, put it back together. Had it done so fast the wife thought I was just taking a whiz after work.
We also have a Briggs mint green toilet in the basement. Inop when we moved in, to my surprise a new flapper valve and we were good to go (little bathroom humor, heh, heh), been working fine for two years.
Git
S Cal
I replaced our flapper valves with these replacement repair kits. They replace the flapper valve, and is dual flush, which helps save water
dogdog
Those leak too... I had them for about 3 years and then ripped them out and replaced it with regular ones... the problem was the zip ties that was used to secure the piston to retrofit... and the piston seal...
bwringer
Indianapolis
Gives me flashbacks... there was a period of about five years where every time I visited my Mom, I ended up as a plumber, usually fixing a toilet. Eventually, I insisted on just replacing all three, then it was a game of musical thrones because she cheaped out with the crappy store brand on two of them "welllllllll... I don't really like that one, can we swap the one in the guest room to the master bath?
Anyway, at some point fixing old toilets becomes pointless. The toilet makers have really figured out this low-flow thing in the last few years. As long as you don't buy the sub $100 store brand crappers, you can get some truly astonishing flush performance for around $200.
59 wagon man
hollywood fla
just like with vehicles you can buy o.e.m. parts and it works like new without reinventing the wheel. i never shut the water to change a flapper. unhook it ,flush it, hold handle till tank is low and change the flapper
Git
S Cal
I find it easier to just turn the 1/4 turn valve off to work on a toilet... The device I posted about is more than just a replacement, they help save water. It has two flush modes. I installed those on all 5 of our toilets 4 years ago and have yet to have any problems with them. Our water pressure is high enough so that if the valve does open because of a leak, you can definitely hear the toilet running to fill the tank back up
G
gahrajmahal
Cincinnati, Ohio
I can always rely on the gang here at the GJ to educate me more on any subject I post about. Thanks! It had been a few years since I had replaced toilet internals, this recent review X3 gave me a little insight I thought I’d pass along.
Happy and safe Thanksgiving everyone!
LS6 Tommy
Northern NJ
My experience is that Korky is not the "go-to" company for generic parts. I've had much better luck with Fluidmaster. Just as an example, the toilet in the guest bathroom is original to the house. I replaced the tank to bowl seal, valve and flapper in 1995. Haven't touched it since. I will use OEM parts whenever its possible.
Tommy
Legion Prime
Leelenau County MI
I never understood the desire to "save water" when flushing. How many flushes till you save a penny? When I flush I want to flush once and be done, not flush 2-3 times and then go find the toilet brush and flush again.
Whenever I have a toilet problem I just pull the tank off and replace everything. The full replacement kits don't really cost all THAT much more than a new flapper valve and they cost way WAY less than spending a day or more running back and forth buying part after part after part. These Fluidmaster PerforMAX kits went in all three toilets in my old store and the toilet at the house. One of them a guy that worked for me had bought and replaced the flapper valve the same day I had bought the whole replacement kit. Yeah the flapper lasted somewhere in the 3-5 month range at which point I then swapped in the full kit. If part of it's given up the ghost the rest typically isn't too far behind and I only ever want to have to go in there once.
Hot shot
Virginia
What Legion said
If the toilet has some age replace both valves
I like fluidmaster also
If u have an American standard toilet less than 5 years old, call them and they will send u the parts for free but you must have another toilet to use until parts get there
theoldwizard1
SE MI
Well the industry finally figured it out !
Many (most ?) of the newer toilet now have a LARGER hole between the tank and the bowl. Clears the bowl in a split second.
Yes, they have a different size flapper.
rlitman
Long Island
That helps. But the bigger factor in flush velocity is how fast the water can exit, not enter. That is controlled by trapway design.
Legion Prime
Leelenau County MI
Yeah, getting less water in faster doesn't actually make a noticeable difference to say nothing of the line leading out to the sewage main. With the anemic amounts of water they want us to flush with because LA has "water shortages" :rolleyes: the article you've dropped off doesn't always make it out to the main. Then the next time you get done with your grunting and groaning that article gets hung up on the remains of it's predecessor and after a while you're calling rotorooter. My toilets are dual flush, #1 and I flush as usual, #2 and I stand there and hold the handle down till the tank's empty. Last person that tried to shame me into some "water conservation" nonsense got thoroughly embarrassed when they couldn't explain how I'd manage to flush the Great Lakes aquifer dry. Hell with the water levels right now that gowk should have been encouraging me because I rather doubt they knew how a septic system works either. :lol_hitti
