Ton ton
Does anyone have one? I am not an expert on the subject. They got a pointy handle for lining holes up. They are kinda hard to find. You use them for doing steel assembly.
...Just the right thing for brute Adjustable work prying piping around and then tightening clamps...
). Seems a lot of the fasteners areas were recessed with not a lot of room, for a larger head wrench.
So these are what you need for laying pipe![]()
FWIW, I've never owned any adjustable wrench, that did not need regular readjusting, during use.
It's been 40 years, since I used a spud wrench (construction worker building a very large steel building) but the fasteners were all the same size (or maybe two sizes at most - it's been a while). Seems a lot of the fasteners areas were recessed with not a lot of room, for a larger head wrench.
It would just seem to make more sense, for ease of use, to just use a dedicated fastener size wrench end, at least on larger jobs, which may be the reason adjustable models are more limited availability![]()
Other than erecting steel structures - which they are a must, is there any other use for them?
Hence, the name.![]()
Farm equipment. Best thing ever for hooking up and swapping implements and attachments.
You can even get a matching ratchet
I had one of the spud ratchets. Got mine from Klein. I was a unique design. Open ratchet wheel with external pawl. To reverse direction you just flip the pawl the other way. Built like a tank. Only ratchet I ever had where I was comfortable using a cheater pipe. Gave it to a millwright when I retired.You can even get a matching ratchet
