Erection adjustable wrenches.
Ton ton
Page County,VA
Does anyone have one? I am not an expert on the subject. They got a pointy handle for lining holes up. They are kinda hard to find. You use them for doing steel assembly.
belvedere
SD
redwrench60
East Tennessee
I’ve got a pair of Klein spuds I use at work a lot. Just the right thing for brute Adjustable work prying piping around and then tightening clamps and lining up bolt holes in large metal parts on equipment.
T
Ton ton
Page County,VA
I appreciate the response . I really wish construction tools would get discussed more on garage journal.
metaldad
nw indiana
adjustable pin wrench - many different manufacturers names on them, all the same wrench.
pin wrenches. one guy here collects them. sold him a few. correct me if im wrong, but kinda remember size dosent follow the jaw opening
alignment pins - come in a wide range of sizes.
zendriver
Indiana
FWIW, I've never owned any adjustable wrench, that did not need regular readjusting, during use. :beer:
It's been 40 years, since I used a spud wrench (construction worker building a very large steel building) but the fasteners were all the same size (or maybe two sizes at most - it's been a while :willy_nil). Seems a lot of the fasteners areas were recessed with not a lot of room, for a larger head wrench.
It would just seem to make more sense, for ease of use, to just use a dedicated fastener size wrench end, at least on larger jobs, which may be the reason adjustable models are more limited availability :dunno:
zendriver
Indiana
Other than erecting steel structures - which they are a must, is there any other use for them?
Hence, the name. :dunno:
metaldad
nw indiana
some manufacturer, years ago, made an adjustable, with a pin that was.......... in the jaw? screw? set it, and it locked the jaw. dad had one, a long time ago
redwrench60
East Tennessee
Absolutely. I use them for aligning the bolt holes of front suspension cradles on front wheel drive unibody cars and SUVs as well as alignment and fastening of large pipe flanges. I use them on hard pipe fuel and hydraulic systems on equipment to service JIC fittings and pry piping around to line up clamps and U bolts. They also take a compact cheater pipe easily to reduce operator fatigue. Basically I’ll add an adjustable spud to the mix whenever there’s a lot of this **** to do. It ALWAYS gets used.
lardy1
Spud wrench. Construction wrench. Erection wrench and probably a host of other tags from specific trades and/or regions. Not particularly hard to find.
redwrench60
East Tennessee
Farm equipment. Best thing ever for hooking up and swapping implements and attachments.
Yup. Unless you’re an Ironworker or Millwright it’s one of those simple tools you might overlook until you see what all they can do. If I could only fit one or two 12”ish adjustable wrenches in my kit, bag or box one of them would be a spud.
alfazer
N. Ireland
They are called a Podger on this side of the pond.
Sounds like todger, which is another word for *****, which I suppose takes things back around to erection again.
I need to grow up.
Junkdrawer Dog
LV NV
Used them all the time for installing drive rolls in the mill. Stick a spud in one hole of the pillow block at each end of the roll, lower away with the crane while a helper guides the tapered end into the mounting holes. Remove spuds, drop in a couple bolts, then use spuds to align remaining holes. Drop in remaining bolts, then couple roll to drive motor. Install hold down nuts and washers, remove locks, power up and then roll some steel!
Junkdrawer Dog
LV NV
You can even get a matching ratchet
I had one of the spud ratchets. Got mine from Klein. I was a unique design. Open ratchet wheel with external pawl. To reverse direction you just flip the pawl the other way. Built like a tank. Only ratchet I ever had where I was comfortable using a cheater pipe. Gave it to a millwright when I retired.
Renegade1LI
long island ny
Yep it's a klien ratchet & wrench, the ratchet is made in Japan & the wrench in USA, both built tough. I also have a couple smaller wrenches great for chassis repair.
redwrench60
East Tennessee
I’ve actually been meaning to buy another 16” adjustable spud for work. I have a 10” and a 16” but I want a pair of 16’s for maximum utility. I scoped out Amazon and HJE and found a 16” Klein adj. spud in “used very good” condition for a discount On Amazon so we’ll have to see what shows up here in a few days. Never bought anything used from them before.
redwrench60
East Tennessee
Well I received my “used” 16 inch Klein adjustable spud and if it’s used I can’t tell. Appears brand new just no Klein packaging. It’ll be a good one, and at a little discount.
