What’s this machine lead/cable connector called?
lilscorpion
Colorado
Need to make an extension cable for my powder coating gun but the MFG (Columbia Coatings) apparently doesn’t know what parts their product is made out of...so I need help.
What are these connectors called? This is a three prong, easy enough...but are the little alignment tabs proprietary (different for each MFG) or are they fairly standard? Any idea where I might be able to source them?
One more clue - a brand?
Thanks!
Matt
cvairwerks
Within hearing distance of Texas Motor Speedway
Should be a connector number on either the plug or the bulkhead fitting. The keyways are not propitiatory, but are specific to the configuration. You need to know the manufacturer and the plug number to find the correct mating connector. I know the brands we use at work have probably 20 different sizes, with anywhere from one to 100 pins and up to 50 keyway configurations.
There are probably a dozen manufacturers that offer the various selections.
If you can't find a number, you would need to select a known plug and bulkhead fitting and change them over.
Dustball
Hudson, WI
You're going to have to take the connectors apart and look for part numbers.
Alternative- make your extension cable but move the existing male plug onto one end of your extension. Buy and install a new pair of male/female connectors to put on the other end of your extension and on the end of the existing gun cable.
Danglerb
SoCal
Clean and easy would be to find matching connectors, there are two other options;
A) Replace the cord with a longer cord using the old connector.
B) Put the connector from this cord on one end of the extension, and a new whatever you find pair of connectors at the other end of the extension and old cord.
pi_guy
N/A
There is a air drying plastic non conductive which I have used to make connector housing.
I have a large collection of pins m/f which I would match and create my own cable.
Otherwise I would lean on manufacturer often they use custom or oddball stuff.
logo does not look familiar.
Buster21
Idaho
Why couldn't you cut the cord in the middle, then install standard male and female 110 volt electrical connectors, then you could use any length extension cord you wanted. I don't know if you want to cut your factory cord in half but just a thought.
L
lilscorpion
Colorado
I’ll take it apart then. Didn’t know there’d be a part number inside. Thanks for the tip.
Yeah, good idea on adding a new connector in the middle. That would work well if I can’t find a match.
L
lilscorpion
Colorado
I will if I can’t find a match. My brain said it would be easier if it did because then the MFG couldn’t void the warranty in the powder coating gun or power supply. Guess if I inserted a new one in the middle I could swap it back should it need to go in for service..
klitzke
Wisconsin
This is a circular connector style. ITT cannon is the original manufacturer of the “cannon plug”. The three prong is a common plug in general aviation for reciprocating engine sensors. Make a call to your local airport and get ahold of the mechanic responsible for on field maintenance. A case of beer and a friendly chat might enlighten you some more or get you the parts you need out of the misc plug bin!
Just take the old part with to line up those tangs - everyone else is correct about the variation there.
Someone correct me if I’m wrong but I’ve never had to pull one of these apart for a part number. It’s generally stamped or printed on the shell somewhere. Start with that and see if a google search of the PN gets you what you need. Be prepared to wade through a few spec sheets and take careful dimensions of your existing part! Sometimes these are not straightforward.
Keep us updated if you have PN troubles.
L
lilscorpion
Colorado
Getting closer thanks to your help all! I’ve been able to construct a rational part number based on a schematic I found on Allied Electric’s website.
srcn6a16-3p
I called allied and they recognize it as a valid part number but not in their system (they’ve never sold one). They’re going to attempt to cross-reference it and see if there’s other options they do stock as well as contact the MfG and see If they can get it. Will know more tomorrow.
Matt
toplessHO
central florida
look on skycrafts website or call them.
They deal in that kinda stuff.
Im pretty close so I get spoiled with the convenience.
I hear ya on the manufacturer not knowing what parts they are made of.
I needed a similar 5 pin connector for my MIG and Metal Man had no idea who the manufacturer was.
A close up revealed the part# and I found more on ebay.
L
lilscorpion
Colorado
Theses JAR connectors were recommended and they’re nearly identical but they’re too small. I’m certain I need this part number
SRCN6A21-3p and SRCN2A21-3s
JAE shoes the same thing I found before - the spec is possible but no item in their catalog that’s available. Still looking.
Here’s the additional info that came on the parts
51422e498f2a5eaeae7397989c5b0c81.jpg48e39f9ab96ba46d3c2100e4a55201ef.jpg46e0a3dba525d1219d1fd43cfb315d01.jpg
L
lilscorpion
Colorado
Off of the various numbers on the packages, I’ve figured out that WSU Aviation connectors appear to be very similar. It isn’t clear yet I’d the threads are the same diameter - they appear to be 20mm vs 21mm. All of what I’m finding are made in Japan or China and for whatever reason, this size in a 3-pin is super rare in the US.
L
lilscorpion
Colorado
Pretty soon you'll have enough parts on hand to make it whatever you want it to be!
I know, silly it does seem. One of two things will happen - I’ll either figure it out and get the right connectors, or I’ll give up when I have a couple of choices for replacing everything. I don’t really want to void my warranty so my preference is to figure it out. [emoji16]
L
lilscorpion
Colorado
Did you know Columbia has a repair service (or at least used to)? Give Brian a call and he might be able to help over the phone.
I called them and they guy I talked to said they don’t have parts for the gun, part numbers, or even know what the connectors were called. He even checked with the techs.
No I suspect he’s full of ****. If he isn’t though, that doesn’t say much for the knowledge of their product or ability to fix pieces or parts. Guess you’d have to buy a new gun if you damaged one of the pins?!
Dustball
Hudson, WI
No I suspect he’s full of ****. If he isn’t though, that doesn’t say much for the knowledge of their product or ability to fix pieces or parts. Guess you’d have to buy a new gun?!?
Most likely they have an outside manufacturer build their products and all they do is just put their name on the products and sell them.
L
lilscorpion
Colorado
Bummer.
Buying a new setup from them was the true reason I found the repair parts for my old workhorse. I was not impressed; it was on the way back to them the next day.
With limited experience coating, and nothing to compare to, I can say the unit I have from them works well. Wish there was a way to demo units. I would have liked to be able to try a few different brands before diving in.
L
lilscorpion
Colorado
Score...freakin’ Amazon actually had it prime. Now what aim I gonna do with the other 2 I’ll get 2 months from now when they make it all the way from China?!
