Brush on gutter sealant?
justanengineer
Motor City
Is there such a thing as a good brush-on gutter sealant? My current project has aluminum gutters that drip at every joint and I’m hoping there is a decent sealant which is thinner than caulk that I could quickly/easily brush onto the joints. I’m not averse to caulking if really necessary but find it a PITA and it seems like a better idea to have sealant flow into the joint rather than just sit on an edge.
atch
Columbia, Missouri
I don't know what it's called or where to get it, but around here the gutter installation companies use something that is silver and flows somewhat. I believe it comes in tubes. After application it runs a bit and smooths itself out. After it dries it's smooth and stuff doesn't stick to it.
I suggest contacting one of those folks to see if they'll sell you a couple of tubes.
matt_i
SE Michigan
That's what I used, silvery, stickiest substance known to man. I got it from an Allied Building Materials roofing & siding yard. It does not flow, quite viscous, but not a drip has been seen from the joints in ~5 years.
Lynden
Southern California
Might be Geocel Instant Gutter Seal. One of the colors it's available in is silver. I used the silver color in 1993 when I installed my gutters. Seems to be working well. It's self-leveling and appears to flow into the seams.
https://www.geocelusa.com/product/instant-gutter-seal-gutter-narrow-seam-sealant/ -- Scroll down. It's also available in squeeze tubes.
I see they also make a PRO Gutter Seal.
https://www.geocelusa.com/product/geocel-pro-gutter-seal/
Call Geocel and ask them if they have a gutter sealant that you can apply with a brush.
JRC3
Southwestern OH
cdestuck
Altoona, Pa
Go to a RV dealer. As for Dicor used for sealing RV roofs. Killer stuff. Clean your gutters well first.
ponjohn
CT
I used to be in the gutter business. I exclusively used Geocel calk. I would not even think about anything else.
brownbagg
i used some white elstromastic from lowes in the tar asile, It ***** for gutters
Mr_fixit
Rustylvania
You remember which one? 2320® & 2321 CONSTRUCTION TRIPOLYMER GUTTER AND NARROW SEAM SEALANT? or GEOCEL PRO™ GUTTER SEAL?
rayra
Escaped from Los Angeles
Henry's elastomeric coatings. Used on RV roofs, shipping containers etc. Get the gutters clean and slop it in, work it into the joints with the brush and give it a few smoothing brushes.
