tool box work top
Blackbyrd
TN
Any one ever get a stainless topper to cover the top of there tool box?
I have a Husky 66" box with the wooden top and I was wondering if anyone had ever looked into replacing the maple top or covering it?
u2slow
BC
Every bottom box I have has a top-box. I have other cheapo/rugged workbenches to beat up on.
I'd probably just put cardboard or plywood over the maple as a protector.
Blackbyrd
TN
yeah I have one of those rubber fender covers on one section of it currently, but I have a stainless table next to it and thats where I got the idea, but I just assumed it would be as simple as swapping out the wood top for the stainless one you see on some of the other boxes they offer. Just not the case
I didnt think about most people having topper boxes anyway
Mr_B
Reading
I find stainless costly and not nice surface, nice bit of steel plate surface treated is great long term hard working top
rubber matt, tempered hardboard or ply work out sensible cost and non marring .
On boxes I use rubber mainly over 2 layers of 3/4 ply and edge trimmed so creates recess for rubber .
rubber easily removed for cleaning or replaced when too scruffy .
If it going be a do it all type work area then perhaps get steel shop cut you some steel plate to your sizes and do front and rear edge folds if needed .
DeeKay
Colorado
+1 for Steel over Stainless, It's cheaper and IMO a much better work surface than the thin SS skins they sell to cover wood tops.
I waited for the local steel shop to have some material close to the dimensions I needed, then had them cut it down to size. It's 1/8" thick mild steel (probably cold rolled since it was shiny when I got it) I countersunk some holes and bolted it through the wooden top with flat head allens on my Proto roll cab. I was afraid it was going to rust at first, but even in the hot/humid box factory that I worked at the time in St. Louis MO I never had any issues with rust.
Jersey Drew
I have a stainless top on my tool box and it works just fine. You want an indestructible surface. Any metal over wood base then bedliner.
Blackbyrd
TN
yeah I have several stainless work tops already in the garage this more of my OCD wanting it to match. I do mostly light mechanic stuff, but the worst they may ever see is a set of heads setting on it? id thought about getting some 18 guage and using the break at work to bend it in the right spot but didnt know if there were other options to do a purchased finished deal
abachman
Illinois
I use a sheet of hardboard and then top it with a heavy duty 3/8 inch thick rubber mat. It is great.
sberry
Brethren, Michigan
I dont wanna work on the box. I wanna pile **** on it I am using. Similar to service cart. I try to strip it once in a while. My bench hangs hammers, adjustables and clamps. I got a couple top boxes but I dont like working from them. I like it cart style with the **** I need on top and next to the bench. Can reach it both coming and going, can pick it up and clean the top of the bench off.
Its location is kind of uniuque due to coming or going to the bench and coming or going out the side door when its open. The sink and battery tools are positioned similar. They are on the way.
oldwino
Sonoma County California (wine country)
I have stainless on mine but I don’t use it as a work surface. Actually the stainless came with the box as a freebie (paid for it, just didn’t show up on the tag). Top is only used for the laptop, radio and todays parts deliveries
Blackbyrd
TN
Buying a sheet is not terribly expensive online shipping it kind of *****, there is a local metal shop I meant see if they could do it
sberry
Brethren, Michigan
I just as soon have common steel on a bench top. I got a couple 3 rolling tables and 2 benches and benches share vise on one and welding on both, cutting on one. Got thousands of little sings from jobs.
Blackbyrd
TN
Found an online metal supplier that would cut to dimensions and ship it. Attached a pic of the end result.
Probably more $ then it was worth, but I'm happy with how it turned out
xjfish
Stainless is easy to clean. I have a stainless top on my Matco work box now and like it. It covers the box "lip" so it can easily be wiped off. I do some limited work on it, no major beating.
tool_scrounge
Southern California
That turned out nice!
The nicest stainless steel top I ever saw was a large Vidmar tool box with a 1.75" thick butcher block top with a 5 sided welded stainless steel box that fit tightly over the wood. The steel was about 0.09" or so thick. Really nicely constructed. But I suspect it was custom and probably fairly expensive.
Toold_up
Attached
Any sheet meal shops in your area? Here they offer different kinds of steel and even copper sheets. Show up with measurements and they will cut/bend whatever you want.
Blackbyrd
TN
There is one shop and they were more expensive then the online store after shipping..... So I went with the online store
will335i
IL
FWIW I plan to use a wood top coated in envirotex when my new box shows up. I have a stainless kitchen sink and it looked pretty when I installed it but between the scratches from dishes and trying to keep it clean, it drives me nuts. I know with how much the stainless tops cost I would be annoyed every time I scratched or dented it and I know it would happen fast since I want to use it as a true work surface.
Mr_B
Reading
I would never bother with stainless .
Steel plate, thick rubber or tempered hardboard makes far better working surface for various usage types .
I swapped out stainless and went mainly rubber besides one cabinet and a bench that does rough work and welding that steel plate.
rubber work great for general mechanical work, non marring, easy clean and easy replace and can be set over ply base board to give pretty hard base and allow vise mounting if required .
Blackbyrd
TN
Oh god no, even on sale the box was $800 I think
Price of the steel cut to fit was 190 shipped after the 20% coupon
Blackbyrd
TN
Stainless is easy to care for. Every so often follow the grain with some steel wool and that will blend the scratches of daily use. I could have gone cheeper but I went with 16 gauge since there isn't much structure with the maple top removed.
