Tyvex house wrap, pole barn PSA
Snip
Crossville, Tennessee
Just a heads up (opinion) on weather or not to Tyvex or not. On my new steel sided pole barn I was on the fence whether to wrap or not. There are many different opinions on here. I would need 3 rolls to do mine, so around 475 in materials, builder would install for no extra charge. I am planing to finish and insulate the inside in the future. Well after going back and forth I pulled the plug and did it, here is my thought. It was money well spent. I had no idea how much air infiltration comes in thru the seams before now. When there is a slight breeze I can hear the wrap "rattle" telling me that I am now keeping that much cooler air out, increasing the efficiency of the insulation when installed. Plus i read somewhere it is rated at a R-3.
Just thought I would pass that along for anybody that might be on the fence.
Stuart in MN
Minneapolis
Tyvek house wrap doesn't have an R value, per the DuPont website. They do make another product called Tyvek ThermaWrap that they say has an R value of 5.0.
HAULNSS
MN
My builder required a wrap or poly if I was to use spray foam for insulation. They said if the spray foam is on the metal it will void the rust warranty due to possibly trapping moisture.
Randy
dcg9381
Austin, TX
Randy
I believe it. It has to be geography specific. There are a ton of hangers up here 10+ years old done in foam, no moisture /rust problems.
If you were to spray closed cell, not sure how they'd claim it traps moisture.
Snip
Thank you for the correction, I could have sworn I had read it somewhere but I guess i was confusing that statement with reading about another product.
greg13
Weedsport, NY
I can tell you first hand that Tyvek DOES make a difference. My new 24x32 is wrapped. I have been in the garage during 2 recent storms with enough wind to take trees down. NO air movement at all and I have no insulation yet.
