I recently had my 40x60x16 steel building insulated with open cell foam. It gets extremely hot here and I wanted the most R value I could get, which is why I didn't go closed cell initially.
Plan was to put R panel inside up 8 feet or so, otherwise no covering over the foam up high, except to paint it white.
It has been 3 weeks since the spray. Doors have been open 90% of the days since then airing out. The smell is so strong with the doors (2 14x16) shut that nobody can even stay in there. Even when the temps are down in the 40s, the smell is present. Significantly worse when its warm.
Anyway, the contractor hired wants to make it right. They have no idea why this happened. Research tells me the mix or application was incorrect. It also looks like this smell won't get any better anytime soon if the mix was bad.
So I think im looking at a complete tear out. I'm ok with this as I want a safe environment for my 2 year old who will be playing out there often.
My questions are:
Go with closed cell after the tear out? Will this have a better chance of not smelling? Paint everything after?
How thick can closed cell be? Some say 2" but I saw others went 3" on here.
Thanks in advance!
My questions are:
Thanks in advance!
