threeputt
Update
I said I was not messing with this Reed anymore but I told a fib
I took it off and I am back at it again and hope someone might share some info on which route I need to take.
This old heavy thing is worth repairing plus I like doing things like this
I included two pictures of it and where the damage is.
Any suggestions on how to fix this ? I am not sure how much cast iron is in it but I can test it with a grinder and see. Maybe just weld up the broke piece and do some grinding ? Maybe I can test by grinding on it to see if it is cast iron or cast steel. As heavy as this thing is I would think cast steel but again I won't know until tomorrow. I am thinking I would need to braze this ?? or nickel rods
Would it be possible to get a new set of jaw plates for this thing ? if I can figure out how to remove whats left in there. I don't see any place it was bolted on but I do see the line where it should be.
This vise seems to be missing the bottom part and was just bolted to stand in 1961 and they went to work. It has had lots of abuse over the years. Most before I got it 41 years ago. I doubt I could ever find the swivel part and they would be fine if I don't. It has worked like this all this time without an issue.
Thanks for any help and sorry I said I was not going to repair this thing.
.I took it off and I am back at it again and hope someone might share some info on which route I need to take.
