Ok, so the snowblower ***** balls, unless you are on a paved surface and there is less than 6” of snow, then it is marginal. I am pretty sure the snow broom uses the same motor, yet it is only 12” wide so it has way more power. I did manage to get something stuck and bound it up good, but once I cleaned it out, we were back to normal. It really shines at the overhead doors, you can easily blow the snow way out of the way and it did a good job oven with deep stuff. You have to kind of come in from the top at the deepest points, but 12” was a straight shot and it worked well. I did find it has a safety on the motor, if it bigs too much it shuts off, you then have to pop the battery out and reinsert it, that seems to clear the problem instantly. All the snow I moved was on one battery, the smallest one too.
