Andy FitzGibbon
- Joined
- Apr 7, 2011
- Messages
- 175
---Would someone Go-Fund-Me a 926?---As Outlaw says, it never hurts to ask.
He wanted it black to match all the toolboxes and racking in his garage. He actually had the idea to file the lettering after paint which I had always wanted to try and am really happy with the results. This one is dated Sept.1944 and while it has certainly been used over the last 76 years, the jaws are still crisp and it's now one finger smooth and good as new!
I know this is the common-as-dirt Wilton vise, but where is the model number?
I need a new pivot locking bolt that mounts under the base.
Got it for free from an estate sale.
Yep Dan, your slide looks bare metal up front but painted in the rear.---Is it bare metal all the way with an optical allusion from the lighting in the pic, or is part of the slide painted?---Probably better to just oil or grease the slide if it is a user cause the paint will cause drag and eventually ware off, but if it is a collector and will see no use, then as Cam Newton says, "it all good".![]()
107 was a non swiveler, the base thats left is all it had.
Here is the reed vise dating thread.
https://www.garagejournal.com/forum/showthread.php?t=400156&highlight=reed+date+thread
Looks to me like someone welded it to a steel plate that's then been welded or bolted to the bench top.If it didn't have the feet broken off, worth probably $500+.
As it sits it is a parts vise. How is it even attached to the bench?
I agree with Davethorik, with the broken mounting ears, it's a parts vise. And since a Rood 107 is far from common, it's not worth much as parts either. With it's ears intact, it's probably worth $400-$500.
The vise appears to have been welded directly to the steel workbench. I guess not a bad way to make the vise have some functionality. Just a crying shame to see a good vise having been somehow destroyed. There had to have been some incredible abuse or foolish mounting method used to break the mounting tabs off the base.
I looked at my Reed 106S and can't imagine breaking even the swivel base's tabs. I suppose there are some 20# sledgehammers in the world and guys using them, maybe that could have done the damage..
PierceA
Thanks, it worked perfectly. bought a 3/8x1-1/2 and cut a 1/4" off and it works fine. The original bolt was just worn out. Now I'm inspired to rebuild it and paint it. It looks like it was originally a very dark gray. Anybody know a good paint match for a Schiller Park Wilton 3-1/2" mechanics vise?Just use a carriage bolt of the appropriate size.
Does anybody make a jaw insert for holding pipes?
Please help with nailing down the identity of this Columbian. The stamp pad says "556", but the first "5" appears to be stamped over an original "6". After these stamped digits is a cast "M".
Look how robust (and long)the fixed-jaw base is! And what's with the lever by the meatball? This model is clearly steel (not iron), as seen in the welds. Someone welded the base down to a huge hand cart, and It's been hidden in plain sight for years.
I could not find this model in any old literature. Any info would be appreciated.
Thanks.
If you’re looking for a gloss finish that’s easy to wipe clean, I suggest Rustoleum Smoke gray. I used it to refinish this little Columbian 63. I used it to repaint my Craftsman drill press and the bench grinder that I converted into a buffer motor to spin my Nyalox brush wheels.
You can get pretty good results with a brush if you’re not set up to spray paint. I used a 3/4 inch wide camel hair artist brush. Thin the paint about 10% with mineral spirits.
The down side to using this paint is that recoat time is 24 hours and although you can handle painted objects in 6 hours or so depending on temps, it takes weeks to fully cure.
And you need multiple coats. I think this vise took 3 to look like this.
I finally got this Quick Release Columbian Model 556 cut free and brought inside for the first time in a good while. It was non-functioning because the quick-release linkage (long metal strip) had come out of a slot underneath the vise. Since the vise was stitched to a boiler plate, there was no access to fix it. So, after a quick fix of the linkage, and a much-needed WD-40 bath, I took a few more photos. I am still searching for any literature mentioning the 556, or any Columbian QR models. Big thanks to KMScott for fielding all of my novice vise questions.
You can also add a catalyst/hardener. Not only will it speed the drying time, it will provide a more durable finish when fully cured."...it takes weeks to fully cure"--unless you give it some help! As I posted last week Here, I used an old toaster oven I bought at a garage sale to cure my vise in three hours. I used Behr Oil-Base Semi-Gloss Enamel. I also brushed it on but only used a single coat so most of the old dings and cuts of its past use would still be visible.
Great pics PSCO, I have a Columbian M series with C style jaws too. Don't see to many around. Also a Columbian with Tee style jaws. Yours is marked Columbian Hardware built in Cleveland. Note the large Dynamic Support and a quick release. Pretty rare vise, first one I have seen. Can you weight it for us. Nice find PSCO. Be sure to post pics of that 6" double swiveler Yost that I seen earlier, the guys here would appreciate it.
It is welded and still works. It's surprisingly smooth believe it or not. He claimed the vise to be almost 100 years old as he is in his late 70's and remembered it as a kid. Remember it is from a rail yard and then was used as in heavy equipment repair so it has had a rough yet useful life
