stickshift
I used to think 2 stage compressor design allows you to reach higher pressure than single stage design. Home Depot has a Husky 175psi single stage, which is a direct competitor to the similarly priced Lowes Kobalt 175psi dual stage.
Husky single stage, 30-gal, 175psi, oiled, belt drive
Kobalt dual stage, 30-gal, 175psi, oiled, belt drive
Interestingly, not only does the Husky have the same psi, it has significantly higher scfm at 90psi (6.2 vs 4.1). How is the Husky achieving this? Better motor?
The motor on the Kobalt has "Duty: CONT." on it, so I assume it's rated for continuous use. Doesn't say anything about it in the manual. The Husky manual says motor is rated for continuous use, but they recommend 50% duty cycle.
Does the rationale for dual stage compressors still exist if there are single stage compressors that can achieve the same compression and produce higher scfm as well? Other than the cool looking 'V' cylinder configuration?
